Tips & Tricks
Work smarter with this selection of tips & tricks to perform any task on your GEOVIA software!
Note that you can access the last posts by clicking on the tips &tricks tag.
 Looking to sharpen your skills on a specific area of your GEOVIA software? Have a look at our upcoming trainings!
💡 Use the anchor on the top right to directly access the sections
▶ Look for the 🆕 (new) icon to see the las tips released.
Surpac tips
 📗 E-book: Top 5 tips in GEOVIA Surpac
CategoryTip
General
Access any folder quickly in Surpac
Opening Surpac in a nominated folder
How to get Dfield information to display when converting string to DXF
Combining Data into a Layer
Enabling point of rotation
Use the move tool
How to improve Surpac performance by configuring the graphics card
Point modes
Orientate text using a styles file
Exporting Solids from Surpac and displaying in 3D in PDFs for presentations and reports​​​​​​​
Planes
Copying Planes in GEOVIA Surpac​​​​​​​
Visual cutting planes
How to display and view data in plan and cross section view in Surpac
Plotting
How to plot oblique sections 🆕
Creating plot with multiple viewports
Using autoplot's multiple viewports
Plotting grid points with grid lines offset
How to rescale and append A3 plots to A0
Top ten Surpac plotting (1/2)
Top ten Surpac plotting (2/2)
How to create a long section puncture plot (1/4)
How to create a Long Section Puncture Plot in SURPAC (2/4)
How to create a Long Section Puncture plot in SURPAC (3/4)
How to create a Long Section Puncture Plot in SURPAC (4/4)
Geology
Drillhole database
Coloring a pit by geology
How to drape and digitise underground wall mapping
How to perform Dynamic Anisotropy
Swath tip on Surpac​​​​​​​ 🆕
Using drillhole constraints
Checking linear clearance around existing and planned drillholes
Structural suite
Part 1 : structural suite
Part 2: structural suite
Part 3: structural suite
Block Modeling
Top Cut Analysis in GEOVIA Surpac 6.7.4
Improve your estimations with variable sub-ceiling
How to decrease the size of a block model
Simple reblock and dilution of grade
Changing the block model coordinate system
Macros
Surpac TCL/SCL Scripts Examples 🆕
TCL scripting in GEOVIA Surpac with guido tables
How to use SLC commands to make points in Surpac
How to use TWAPI in a Surpac macro to read directly from a spreadsheet
How to use TCLODBC in Surpac to write to a Microsoft Access database
How to use SCL commands to make points in Surpac
@AC's Surpac tips series
Episode 1
Episode 2
Episode 3
Episode 4
Solids/DTMs
Merging DTMs
Automatic and manual triangulation methods of solid modeling
Achieving faster solids conditioning
How to extract and display gradient information from a DTM surface
How to see the difference between planned and mined solids 🆕
How to see the distance between drilling and planned underground workings? 🆕
Converting historical 2D plans into Surpac 3DM solids
Splitting trisolations in GEOVIA Surpac v6.8
Contouring
Contouring soil assay results using grid method
Contouring soil assay results using DTM method
Point cloud
Creating grayscale colour DTM surface model from RGB point cloud
Working with Point Clouds 🆕
Meshing cloud points faster
Pit design (Engineering)
Pit design top to bottom
Designing ramps with varying slope angle and berm width
Creating dump block models in Surpac to use in MineSched
More tips:
File conversion from latitude and longitude to a grid reference system to enable use in Surpac
MineSched tips
Importing Haul Route names into GEOVIA MineSched
Displaying a block model
Improving accuracy with partial percentages
Part 1: using rimpull table
Part 2: using rimpull table
Update haul roads that have been adjusted in Surpac (GMP)
How to incorporate existing production schedule with LOM study
How to get optimum results out of the trucks calculation
How to embed MineSched schedule animation into 3DEXPERIENCE platform 3D Play
MineSched tip - Animate MineSched schedules with blocks colored by material class
Copying Graphics for presentations
Scheduling​​​​​​​
Whittle tips
3 Tips to Declutter Your Workspace​​​​​​​
⚠Warning the Pit may hit an edge​​​​​​​ 🆕
Converting a definition tab into a report template
Slope profile generation
Using mining direction for pushback generation
How to merge block models
Including con attribute​​​​​​​
GEMS PCBC
How to rename an old GEMS project for PCBC
Exploring the PCBC undercut modeling tool
Using offset display
How to set up a new PCSLC project
Using Bucket Transfer tool to setup Offset Display Mode for GEOVIA PCSLC
How to use Pie Chart Display for Rock Type
GEOVIA
Creating an installation log file
A guide to GEOVIA Stope Optimizer
