How to customize EKL Script for DELMIA Machining
List of EKL scripts related to DELMIA Fabrication.
Sr.No.Page TitleContent Description
1How to determine EKL Type of the Objects and Get List Attributes and Associated FunctionsIntroduction to Language Browser and its use in EKL scripting
2Business Rule to Define the Format and the Text of Choreography Text EventsHow to implement a Business Rule to Define the Format and the Text of Choreography Text Events
3Business Rule for Machining Resource InitializationHow to implement Business Rule to Define initial standard values of tool parameters in Machining Resource.
4Business Rule to Edit specialized attributes of Machining ResourceHow to implement Business Rule to Edit the specialized attribute values such as "Name" for Machining Resource
5Business Rule for Machining Resource UpgradeHow to implement Business Rule to Define the initial standard values of tool parameters while upgrading the Machining Resource
6Business Rule for NC Geometry Part InitializationHow to implement Business Rule to Rename the Auto-generated NC Geometry Part (or Physical product for geometry storage)
7Business Rule on How to Publish NC DocumentsHow to customize the business rule for the publication of NC files as Documents.
8Business Rule for Tool QueryHow to customize the logic of tool query to select the required tool while instantiating Machining Know-How Template
9Business Rule that Checks adding Holder Component in Tool AssemblyHow to customize the Business Rule that checks the compatibility of holder component with tool/holder from tool assembly while adding it to the tool assembly.
10Business Rule to Validate NC Program before NC Output GenerationHow to customize the Business Rule that enables user to check and rework the NC Program before the NC Code gets created
11Business Rule for NC Assembly Assignment
How to set initial setup position attributes like Rough Stock, Design Part, Fixture, Feeds and Speeds Configurations, during NC Assembly assignment to setup position.
12Business Rule to Categorize Parameters in Parameter Panel
How to customize the categorization of parameters in the Parameters Panel while editing the tool parameters.
13Business Rule for Attribute Mapping, P&O and Maturity Management during Fabrication FBDI ImportHow to configure the business rule script for attribute mapping and PnO, Maturity mapping during File Based Design Import (FBDI) of CATProcesses, CATParts from CATIA V5.
14Business Rule for Interpolation Axes CreationHow to automate Interpolation Axes creation process when defining Multi-Axis Curve machining operation.
15Business Rule for MAF (Machining Axial Feature) User AttributesHow to automate the user attribute creation on MAFs (Machining Axial Features)
