Can I get comparison for Software/Hardware requirements for 23x vs 26x ?
I know I can find in PDIR but need to check it separately , Do we have  comparison any where else ?
ENOVIA User Community
Public
Post
Media
Question
Wiki
WeDo
Survey
May 2026 | ENOVIA News
Welcome to the May edition of the ENOVIA User Community newsletter! This edition highlights a recent ENOVIA User Community gathering, What's New in R2026x FD02, a webinar replay, an inspiring Expert Angle interview, and more. Happy reading!
News and Events
🔸 ENOVIA Beyond the Basics Webinar: Prepare Your Engineering BOM for Manufacturing & Service BOMs | June 3
Unlock the secrets to creating a well-structured
Export Specification to ReqIF format
Kais ROMDHAN3 day(s) ago
Hello, I would like to confirm whether it is possible to generate a ReqIF format directly from the web application for a requirement specification. If this is not supported, what solution do you recommend, considering that we plan to use the Collaboration Package as the exchange mechanism for these formats?
Thank you
0
1
Alexandru Dobra3 day(s) ago
Hi @Kais ROMDHAN.
I don't think that ReqIF format is available as Export format for Requirements from 3DX directly. If I remember well, you need to connect Reqtify (DS application --> https://www.3ds.com/products/catia/reqtify) to 3DX and perform the export from Reqtify after you open the requirement using the connector.
The System Traceability App is able to "read" ReqIF files directly.
1
0
Issue generating derived outputs from 3D Product
Hello, I’m encountering an issue when generating derived outputs from a 3D Product containing geometry. Each time, a job is created but nothing is produced, and I haven’t been able to identify the cause. Could you help me understand what might be happening? The CAD origin is SolidWorks, reproduced in 26XFD02 and 23X no job created:
Thanks for your support.
0
3
Patrick Voosen3 day(s) ago
Is it specific to this part or are you unable to generate any STP files? Was it working at one time and has now stopped working?
0
0
Ichiro MARUI8 hour(s) ago
I'm not sure if your case with SOLIDWORKS is the same, but in my case with CATIAV5, STS (Conversion Data Integrator for STEP Multidiscipline) was additionally required to generate derived outputs in STEP format on demand while other formats could be generated when only Derived Output Converter was available.
0
0
Error Login addon to RMC collaboration for Microsoft 2026x FD02
Ahmad Wazzan4 day(s) ago
In 2026x FD02 on Promises, after installing the RMC Collaboration for Microsoft add-in and the hotfix from Native View, the following issue occurs:
0
1
hi @Ahmad Wazzan when the blank pop-up window appears, did you try to press F5 or SHIFT+F5 to force a refresh of the webpage where the user need to select the Credential? Sometime I face the same issue and F5 works well for me.
0
0
Distributed Supplier Collaboration
Anat LANDAU6 day(s) ago
Introduction
We provide different ways for OEMs to collaborate with suppliers on the 3DEXPEREINCE Platform.
The two main collaboration models are:
Integrated Collaboration
In an integrated collaboration model, trusted suppliers are invited directly into the OEM environment using a dedicated security context. Suppliers can access only the data and projects
16
0
May 2026 | ENOVIA User Community News
Leah CHATALIAN6 day(s) ago
May Highlights Include:
🌟 Join us at the 3DEXPERIENCE Conference EuroCentral - Where Virtual Twins Meet Industrial AI on June 16
💻 Upcoming ENOVIA Webinars:
🎤 Exclusive Expert Angle Interview with Harold SULLIVAN, Vermeer Corporatio
1
0
Bulk replacement with a different part within WEB app
Ichiro MARUI1 week(s) ago-Edited
We are looking for an efficient way to perform a bulk replacement of a part used in multiple different assemblies with another part within a WEB application.
In the former Engineering Central, we could perform “Where Used” on a part and create an ECO to perform a bulk part replacement for multiple parent assemblies found on the "Where Used" screen. Even so, customers at the time often gave negative
How to know product configurations in which an engineering item is used
In 150% EBOM management, we are looking for an efficient way to check which product configurations within that 150% EBOM are using a particular engineering item.
Using the OOTB functions, we are now taking the following steps:
1. Searching for the root Physical Product on the “Relations” screen for the target item
2. Filtering each found Physical Product by each Product Configuration to extract
Useful Tip✅| Quick Access to the ENOVIA User Community
Rick HAHN1 week(s) ago-Edited
Conversations
55Communities
Virtual Companions
Calls
Me
Network
Public
Post
Media
Question
Wiki
WeDo
Survey
News and Events
Thank you
0
1
Hi @Kais ROMDHAN.
1
0
0
3
0
0
0
0
0
1
0
0
Introduction
16
0
1
0
Did you know?
You can quickly access the ENOVIA User Community, and other communities you have access to, directly from your 3DDashboard
How?
Select the question mark in the far right corner of your 3DDashboard and follow the prompts.
ENOVIA User CommunityPublic
Draft saved
Did you know?
How?
Draft saved
