Use Case Video Highlight
How Can AI Virtual Companions Help Me?
Automatically turn your CAD assembly into clear, up-to-date assembly instructions with visual snapshots taken from the model and components. LEO will understand the feature tree hierarchy, mates, and other relationships to generate a logical assembly sequence. The resulting document can be quickly shared with stakeholders to clarify design intent, manufacturing specifications, or product changes.
Assembly Instructions Generation: Ask LEO to generate draft assembly instructions for the current assembly
Prerequisites and Set Up
AURA and LEO AI Virtual Companions can be accessed directly within SOLIDWORKS Design via the Virtual Companion tab in the task pane.
To access AURA and LEO AI Virtual Companions, you will need access to a recent version of SOLIDWORKS Design and be connected to the 3DEXPERIENCE platform.
- SOLIDWORKS Design (Named-User License)
- SOLIDWORKS Design with Cloud Services (Device-Locked License)
- Have the Collaborative Designer for SOLIDWORKS role granted to you
- Install the Design with SOLIDWORKS application
Note: Version 2026 SP3.2 or later is required to use the AI Virtual Companions in SOLIDWORKS Design
Installation guidance can be found in the Install Your Roles and Applications section of the Getting Started Guide.
<i>Note: Users do not need to save any of their files to the 3DEXPERIENCE platform to use AURA or LEO.</i>
How To
In your SOLIDWORKS Design session, open an assembly from the 3DEXPERIENCE platform or from the local file system.
From the Virtual Companions tab in the SOLIDWORKS Task Pane, select LEO.
To get LEO to create step-by-step instructions, type the prompt "Generate draft assembly instructions from the current assembly" in the Start Writing area, followed by the Enter key.
After a few moments, LEO lists the steps that will be used to generate the instructions for you to review. If you need to reorder any of the steps or start the assembly from a different component, you can add a follow-up prompt.
When you're ready to finalize the assembly instructions, click on the button "Generate PDF Preview".
Visual snapshots are taken for each step, and the instruction document is generated. You can export the finalized instructions to PDF for easy sharing.
Tips and Recommended Practice
You can open an earlier assembly instruction prompt conversation if you need to create a new copy. Just add a prompt like "Regenerate assembly instructions", and you'll be able to export a new PDF after the preview.
Suppressed components are not included in the instructions. Top-level hidden components and subassemblies are.
A fresh rebuild of the assembly will help ensure the visual snapshot thumbnails are most accurate and up to date.
Each generation is derived from the current CAD state. If the assembly and/or components have changed, revisit the prompt and use the "regenerate assembly instructions" prompt or start a new conversation.
Explore Related Use Cases
| Use Cases and Description | |
LEO | https://r1132100503382-eu1-3dswym.3dexperience.3ds.com/community/swym:prd:R1132100503382:community:52?content=swym:prd:R1132100503382:wikitree:p6hf1RgDQrWKcDF7qg6mFAUse the LEO AI Virtual Companion to evaluate the performance of your assembly in SOLIDWORKS Design. |
AURA |
Use AURA's SOLIDWORKS Insights, providing general guidance on using SOLIDWORKS and recommended best practices |
LEO |
Use LEO's What's Wrong Analysis to provide deeper insights to understand and learn how to fix failed model features. |
