Learning Edition FAQs
You can view the table of contents by clicking on the anchor symbol (top right) and then you can jump to the answer you are looking for.
About the Learning Editions
🟢Are the learning editions free?
Yes
🟢Are the learning editions available for macOS or Linux?
No, the learning editions are available on the Windows platform only.
🟢Where can I find the installation guides for the learning editions?
Abaqus Learning Edition 2025 Installation Guide and CST Studio Suite Installation Guide
🟢I need more features than are available in the learning editions
Please go to our SIMULIA for Students and Academics​​​​​​​ webpage for more information.
Installation Issues
Technical support is not provided.
🟢Media check report failed
Use 7-zip to extract the archive
🟢Abaqus Error: Abaqus/CAE Kernel exited with an error
This error usually indicates that Abaqus/CAE worked but exited with an error or Abaqus/CAE crashed on startup. There can be different causes of this. Try:
1. Running Abaqus/CAE in verbose mode and looking at the contents of the output might give more details on what is going on.
In a command line shell (cmd.exe) window:
e.g. abq2022le cae –verbose 2
2. Looking at the installation logs to determine if the installation failed or is incomplete.
Contents of \\CAE\\2022LE\\InstallData\\log
e.g. c:\\SIMULIA\\CAE\\2022LE\\InstallData\\log
This error can occur when you start CAE in a directory that is not writable.
e.g. in a non-admin cmd.exe shell window
·        Starting CAE in a directory that is not writable
C:\\Windows\\System32>which abq2023le
C:/SIMULIA/Commands/abq2023le.bat
C:\\Windows\\System32>abq2023le cae
IOError: abaqus.rpy: Permission denied
Abaqus Error: Abaqus/CAE Kernel exited with an error.
If you start CAE from the Windows shortcuts, it should work fine.
If it does not, please contribute to tracking down this issue via the existing Swym post.
Further links
Communities of interest
SIMULIA Learning Resources can be found at:
In this wiki:
