🍳 Creating Aero Prep-Ultralight Cooking System
This is Aero Prep!
This is my solution for an ultra-light, multi-functional cooking and prep platform. This is solely designed and engineered for long-distance hikers and extreme outdoor enthusiasts.
Cooking miles off-grid is usually chaos—balancing pots on uneven ground, cutting food on rocks, and digging for gear. I built Aero Prep to bring order to the trail.
Aero Prep is an ultralight, all-in-one prep station and cutting board engineered directly for remote backcountry miles
📺🎬 Check out the video below 🎬📺
If you know me, you know how much I love the great outdoors. Remote backcountry archery trips and long trail hikes have taken me into some of the wildest places.
When you’re packing all your survival/camping gear miles past the trailhead, every single ounce counts—and let’s be honest, cooking out there is usually a complete disaster.
You’re balancing a boiling pot on uneven dirt, slicing ingredients on a semi flat rock, and wasting valuable time digging through your pack just to find a lighter or a fork. So I decided to make a change and get organized!
Instead of sketching up concepts, I grabbed some scrap cardboard, masking tape, and a utility knife. I created a physical template directly around the burner itself. Within a few minutes, I had a working product in my hands. This rapid mock-up immediately brought life into my idea. I had the minimum cutting surface needed, where the bi-fold wings had to pivot, and where the primary utensils could nest without adding bulk.
With real-world dimensions validated, I transitioned into SOLIDWORKS Design to build the production geometry. The unit is built as a split two-piece chassis that hinges directly in half for transport. I integrated rotating exoskeleton stabilizing legs underneath that swing down to establish a solid, level foundation where ever needed.
In the SOLIDWORKS Design assembly, I reverse-engineered the exact contours of my trail spork, fixed-blade prep knife, and mini Bic lighter, carving dedicated friction-fit retention pockets directly into the structural deck. One half secures the burner base and pot, while the opposing wing doubles as a dedicated food-prep cutting board.
Once the 3D model was dialed, it was time to hit print and bring it to life. Getting moving parts to fit together straight off the build plate is always a battle of tolerances. My first print wasn't perfect, and prints two and three needed some tweaking with the tool pockets. But print number four was money—zero rattle, clean tolerances, and everything snapped right into place.
I pinned the two halves together with a stainless steel rod down the center, giving the whole platform a serious backbone. It was insanely satisfying feeling every part snap solidly into place. Out on the trail, the last thing you want is gear clanking around in your pack, so nailing those tight tolerances meant every tool and hinge locked down rock-solid and remained completely silent.
Modeling in CAD is satisfying, but testing custom-fabricated hardware miles into the backcountry is where the design proves itself.
In camp, Aero Prep completely changes food prep: it gets your stove, fuel, and meal prep up off the dirt, provides a clean cutting board, and keeps your essentials within immediate reach.
It took a few iterations to get the details dialed, but the final result exceeded my expectations. I’m especially stoked on how ultralight it turned out without losing any structural strength.
Out here, extra ounces turn into heavy pounds fast. Whether you’re pushing miles deep into remote backcountry or just catching a sunset at a scenic overlook, having a rock-solid, compact kitchen to prep food and cook a hot meal changes everything.
Aero Prep has officially earned a permanent spot in my pack.  It will definitely be with me for my next adventure!
Check out the video below to see my entire process. 🎬📺
