Pre-Commit Trigger Execution Guide for Common Web App Operations
Wondering which pre-commit triggers are invoked for a specific operation? This wiki maps common DELMIA web application operations to their complete pre-commit trigger execution sequence, helping you analyze behavior, troubleshoot issues, and develop customizations with confidence
Note: The object on which the trigger is executed is specified using the <strong>business object name</strong> instead of its EKL type or physical ID. If the trigger is executed on a related object (for example, the parent of the object), the relationship with the object is explicitly mentioned.
Table of Contents
Category Operations Covered
CreationCreate a Workplan, Create a Manufacturing Item, Insert Workplan under a Header Workplan
DuplicationInsert Duplicate Workplan under header Workplan, Duplicate from toolbar, Insert deep duplicate Workplan under header workplan
Instance ManagementCreate Instance, Move header operation from one workplan to another workplan, Detach instance of Header Operation from Workplan
RevisionReplacing Header Operation by latest revision/ new revision, New revision, New branch
LifecyclePromote, Demote
Scope LinksScope link between Manufacturing Assembly and Physical Product, Delete scope link, Reconnect scope link
Change Impact ManagementManufacturing Items Management  & Process Management operations
ThisObject Mapping for LinksLink Object Types
Creation
Operations
Steps
Sequence of pre-commit triggers
Create a workplan
Precommit Initialization at Creation (Workplan)
Precommit at New Initialization (Workplan)
Precommit at Modify Attribute (Workplan)
Precommit Initialization at Creation (Manufacturing Item)
Precommit at New Initialization (Manufacturing Item)
Precommit at Modify Attribute (Manufacturing Item)
Precommit While Adding an Interface (Manufacturing Item)
Connect Called (Workplan)
Connect Called (Header Workplan)
Precommit at Create (Workplan Instance)
Duplication
Operations
Steps
Precommit at Copy (Workplan)
Precommit at Modify Attribute (Duplicated Workplan)
Precommit at Batch Clone (PLMCoreReference)
Connect Called (Duplicated Workplan)
Precommit at Create (Duplicated Workplan Instance)
Precommit at Lifecycle Operation Propagation (Workplan)
Same as duplicate
Instance Management
Operations
Steps
Create Instance
Precommit at Create (Workplan Instance) [Output]
Connect Called (Workplan Under Which We Want to Move a Header Operation)
Connect Called (Header Operation)
Precommit at Create (Header Operation Instance)
Precommit at Disconnect (Workplan From Which We Have Moved Header Operation)
Precommit at Disconnect (Header Operation)
Precommit at Delete (Header Operation Instance)
Precommit at Disconnect (Workplan)
Revision
Operations
Steps
Precommit at Major Revision (Header Operation)
Precommit at Change Name (Header Operation)
Precommit at Modify Attribute (Header Operation)
Precommit at Batch Revise (PLMCoreReference)
New revision
Same as above
New branch
Precommit at Lifecycle Operation Propagation (Header Operation)
Precommit at Copy (Header Operation)
Lifecycle
Operations
Steps
Promote a Workplan
Precommit at Promote (Workplan)
Demote
On MFN, MGA, RME precommit at promote is
called
Scope Links
Operations
Steps
Precommit at Connect (Manufacturing Assembly)
Precommit at Connect (DELFmiProcessImplementCnx)
Precommit at Modify Attribute (DELFmiProcessImplementCnx)
Delete scope link
Precommit at Disconnect (Manufacturing Assembly)
No trace
You can repair inconsistent implement links between structures. Open EBOM and MBOM structures in the Manufacturing Items Management application (MFN) or MBOM and Process structures in the Process Management application (MGA). The structures should contain inconsistent links.
From the Authoring section of the action bar, click Change Impact Management (CIM).
The Change Impact Management panel displays, proposing actions to correct the inconsistent links.
Note: You can select a root Manufacturing Item . Process directly in the tree. In this case, the command retrieves all inconsistent links for the selected item and its children.
CIM in Manufacturing Items Management App:
Operations
Steps
Replace by new revision
Precommit at Major Revision (Manufacturing Assembly)
Precommit at Change Name (Manufacturing Assembly)
Precommit at Modify Attribute (Manufacturing Assembly)
Connect Called (Parent of Manufacturing Assembly)
Connect Called (Manufacturing Assembly)
Precommit at Create (Manufacturing Assembly Instance)
Precommit at Disconnect (Parent of Manufacturing Assembly)
Precommit at Delete (Manufacturing Assembly Instance)
Replace by new
Precommit at Modify Attribute (Provided Part)
Precommit While Adding an Interface (Provided Part)
Connect Called (Parent of Provided Part)
Connect Called (Provided Part)
Precommit at Create (Provided Part Instance)
Precommit at Disconnect (Parent of Provided Part)
Precommit at Disconnect (Provided Part)
Precommit at Delete (Provided Part Instance)
Replace by new branch
Precommit at Copy (PLMCoreReference)
Precommit at Disconnect (PLMCoreReference)
Delete
Precommit at Disconnect (Manufacturing Item Parent)
Precommit at Disconnect (Manufacturing Item)
Precommit at Delete (Manufacturing Item Instance)
Reroute
No trace
Evolve Instance
Precommit at Modify Attribute (Provided Part Instance)
Use Case Assembly
Precommit While Adding an Interface (Manufacturing Assembly Instance)
Use Case Fabrication
Precommit at Modify Attribute (Manufacturing Assembly Instance)
Remove Use Case
No trace
CIM in Process Management App:
Operations
Steps
Reroute only
Precommit at Connect (MfgProductionPlanning)
Removelink
Precommit at Change (Manufacturing Assembly)
Delete
When creating a scope link, use the corresponding object type (ThisObject) as shown below:
Scope Link
Required Object Type (ThisObject)
Engineering Item ↔ Manufacturing Item
Manufacturing Item ↔ Process
Capable Resources Link
DELAsmProcessCanUseCnx
Manufacturing Responsibility Link
DELMfgResponsibilityCnx
Authors
For any queries, please reach out to: @AB @PG
