🎓 Success Path: Mechanical Designer
Mechanical Designer
The CATIA Mechanical Designer role allows the users to create and complete advanced mechanical products and parts, from conceptual to detailed phases.
🧑‍🤝‍🧑 Your profile
You want to create Parts and assemblies. You want to create sheet metal parts and assemblies using CATIA.
You want to collaborate efficiently through the 3DEXPERIENCE platform.
You have onboarded on the 3DEXPERIENCE platform
⌚ Estimated time
Onboarding: 8h
🧑‍🏫 Your learning path starts here
Learn how to use the Mechanical Designer Role and its Apps and get certified as a 3DEXPERIENCE Mechanical Designer - Associate.
Discover the value and usage of your roles and learn about their main apps articulation
Explore the Mechanical Designer Role
In this learning module, you will learn to design and modify mechanical parts and assemblies using design methodologies such as solid modeling and surface modeling. You will assess their manufacturability. You will also learn about the know-how of parametric design and concurrent engineering.
<i><strong>Key Concepts Covered:</strong></i>
📌 Create associated parts using various disciplines like mechanical parts, mechanical sheet metal, and plastic parts
📌 Design surface geometries
📌 Build sheet metal parts
📌 Reuse and modify external CAD models
📌 Construct and modify assemblies
📌 Validate the manufacturability of parts
📌 Generate part and assembly drawings
📌 Create and use component families and smart mechanical components
3DEXPERIENCE Mechanical Designer [hands-on] - Associate
This certification validates knowledge and skills on the Mechanical Designer role within the 3DEXPERIENCE platform. This exam proposes hands-on challenges that will require you to design and modify parts and assemblies. You will also be asked multiple-choice questions (MCQ) on how to create 3D parts, create and modify assemblies, analyze parts and drafting. This exam includes exercises that require a 3DEXPERIENCE platform access including the apps related to the Mechanical Designer role. Prepare this exam by watching this video
Deep dive into the most important features of the key Apps and their practical usage in projects.
Start with technical videos 👉
Discover powerful features of Assembly Design
Discover advanced features of Assembly Design
Discover Life Cycle Management, Data Exchange with OEMs, Task Management, Issue and Change Management, Using Dashboards
Practice CATIA Part Design
In this learning module, you will learn how to create 3D models using the CATIA Part Design app. You will also learn how to use different feature-based tools to build a 3D model. Further, you will also learn how to add parameters, reuse data, create models using tables, and modify a model.
📌 Create and constrain 2D sketches
📌 Design fully associative models in 3D
📌 Design reusable features
📌 Parameterize a model
📌 Use Multibody Boolean operations
Practice CATIA Drafting
This module will teach you how to create drawings using the Drafting app. You will learn how to create projection views and section views of a 3D model or an assembly and add the required dimensions.
📌 Create simple projection views and section views of 3D parts and assemblies
📌 Position the views on a drawing sheet
📌 Add dimensions and annotations to the views
Practice CATIA Assembly Design
This learning module will teach you how to create and manage assemblies and sub-assemblies in the design context. You will manage the positioning of parts and analyze assemblies. You will also modify the design in the assembly context.
📌 Create and manage assemblies
📌 Manage the positioning of parts
📌 Create engineering connections to specify the degrees of freedom of components
📌 Modify design in the assembly context
📌 Create flexible assemblies
📌 Calculate, declare and examine the weight distribution of assemblies
📌 Replace components
Practice CATIA Generative Wireframe and Surface
This module will teach you how to use the Generative Wireframe and Surface app to create curves and surfaces. You will learn to efficiently assemble, re-limit and connect geometries. You will also learn to analyze the wireframe and the surface quality and rectify the detected defects.
📌 Create curves and improve the quality of imported wireframes
📌 Create surfaces using wireframe geometries
📌 Assemble, re-limit and connect the surfaces to achieve topology
📌 Analyze surface quality and heal defects
Practice CATIA Sheet Metal Design
In this module, you learn about the importance of sheet metal design. You will learn how to design a sheet metal part and make it ready for manufacturing. You will learn to define the sheet metal parameters and create a part using basic features.
<i><strong>Key concepts covered:</strong></i>
📌 Explore different apps used for the sheet metal design and explain their advantages
📌 Define sheet metal parameters
📌 Create sheet metal parts using walls, bends and cutouts
📌 Manage folded and unfolded views
📌 Create stamped features and flanges
📌 Prepare part for manufacturing with sheet metal order process, DXF file and drawings
📌 Manage the design change
3DEXPERIENCE Mechanical Designer - Professional
This certification assesses your knowledge and skills with CATIA modeling techniques after initial training and a minimum of three months of regular practice using CATIA Mechanical Design core products (Part Design, Assembly Design, and Drafting).The exam proposes hands-on challenges based on industrial use cases that will require you to design, modify and analyze parts and assemblies. Understanding of design intent and drafting principles is assessed in multiple-choice questions.
Enrich your usage through advanced apps or additional roles
                                           EXPAND your capabilities with advanced apps of your role
Practice CATIA Smart Mechanical Components
In this module, you will learn how to define and reuse smart mechanical components. You will also learn how to define component specifications and place the component on the component specifications. Additionally, you will learn to define adaptive components.
📌 Define smart mechanical components
📌 Specify the various types of smart mechanical components type
📌 Define component specifications (anchors)
📌 Instantiate, reuse, place, move or delete smart mechanical components
📌 Create adaptive components
                                    EXPAND your capabilities with additional roles
Mechanical Engineer
Mechanical and Shape Designer
Mechanical & Shape Engineer
Specialized Roles
Strengthen your skills & network with peers!
👉 Join CATIA USER COMMUNITY to learn more about CATIA and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask questions, like and help in our online community!
👉 Join the CATIA Creative Design & Styling - User COMMUNITY
Our global community for designers, creatives & users of our creative design, surfacing & VR solutions to network and share their knowledge. Here, you can learn about design trends, processes and roles in 3DEXPERIENCE CATIA design and styling, as well as our VR and surface refinement solutions. Plus, you can interact directly with our champions and experts, view tutorials, webinars and event information, and ask questions. Help make this community yours by joining and contributing today.
👉 Join the 3DEXPERIENCE platform user's community to learn more about the 3DEXPERIENCE platform and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask a question, like, and help in our online community!
👉 Join the ENOVIA User Community to learn more about the ENOVIA brand and to connect with your peers.
User Success Path
CATIA
MDG-OC
