๐ŸŽ“ Success Path: Mechanical and Shape Engineer
Mechanical & Shape Engineer
The CATIA Mechanical & Shape Engineer role allows the users to enhance mechanical product design quality, through a highly accurate & reliable 3D geometry, supporting very large assemblies and complex surface design, including full model based definition for product manufacturing information as well as human centric design approach. It is also possible to simulate static load cases and kinematics.
๐Ÿง‘โ€๐Ÿคโ€๐Ÿง‘ Your profile
You want to Cover the end-to-end process for mechanical engineering & pre-production studies. You want to Reduce time to market with best-in-class detailed design apps. You want to Explore innovative solutions and concepts on single parts and large assemblies. You want to Define the right detailed design the first time reusing existing designs and templates. You want to Anticipate product manufacturing information through the full definition of 3D Tolerances & Annotations in the same model
You have onboarded onย ย 3DEXPERIENCE platform.ย
โŒš Estimated time
Onboarding: 6h 40m
๐Ÿง‘โ€๐Ÿซ Your learning path starts here
Learn about a complete and powerful set of applications to create and manage sophisticated mechanical products, including advanced surface, 3D annotations and static and kinematkcs simulation.
Please find here your success path forย Mechanical and Shape Engineer.ย If you follow each part of it, you will quickly become an expert.
ย
ย
Explore the Mechanical and Shape Engineer Role
In this learning module, you will learn the key capabilities of the Mechanical and Shape Engineer role to create and easily manage a complex mechanical engineering project
<i><strong>Key concepts covered:</strong></i>
๐Ÿ“Œ Create assembly symmetry
๐Ÿ“Œ Design a sheet metal part
๐Ÿ“Œ Design parts using advanced Part and Surface modeling capabilities
๐Ÿ“Œ Perform a static study
๐Ÿ“Œ Create 3D Annotations
๐Ÿ“Œ Create Kinematic Simulations
3DEXPERIENCE Mechanical & Shape Engineer - Associate
This certification validates your knowledge and skills on the Mechanical & Shape Engineer role within the 3DEXPERIENCE platform. You will be asked multiple-choice questions (MCQ) on creating different forms of 3D components such as solid and sheet metal parts. You will also be accessed on your ability to modify existing parts, analyze assemblies or parts and animate the mechanisms. Additionally, your knowledge will be tested on creating parts and assemblies for manufacturing purposes.
ย
Deep diveย into the most important features of the key Apps and their practical usage in projects
ย
Start with technical videos ๐Ÿ‘‰
ย
Discover powerful features of Assembly Designย
ย
Discover advanced features of Assembly Design
ย
Discover Life Cycle Management, Data Exchange with OEMs, Project Planning, Issue and Change Management, Using Dashboards ย
Practice CATIA Part Design
In this learning module, you will learn how to create 3D models using the CATIA Part Design app. You will also learn how to use different feature-based tools to build a 3D model. Further, you will also learn how to add parameters, reuse data, create models using tables, and modify a model.
๐Ÿ“Œ Create and constrain 2D sketches
๐Ÿ“Œ Design fully associative models in 3D
๐Ÿ“Œ Design reusable features
๐Ÿ“Œ Parameterize a model
๐Ÿ“Œ Use Multibody Boolean operations
Practice CATIA Drafting
This module will teach you how to create drawings using the Drafting app. You will learn how to create projection views and section views of a 3D model or an assembly and add the required dimensions.
๐Ÿ“Œ Create simple projection views and section views of 3D parts and assemblies
๐Ÿ“Œ Position the views on a drawing sheet
๐Ÿ“Œ Add dimensions and annotations to the views
Practice CATIA Assembly Design
In this learning module, you will learn how to create and manage assemblies and sub-assemblies in the design context. You will manage the positioning of parts and analyze assemblies. You will also learn how to modify the design in the assembly context.
๐Ÿ“Œ Create and manage assemblies
๐Ÿ“Œ Manage the positioning of parts
๐Ÿ“Œ Create engineering connections to specify the degrees of freedom of components
๐Ÿ“Œ Modify design in the assembly context
๐Ÿ“Œ Create flexible assemblies
๐Ÿ“Œ Calculate, declare, and examine the weight distribution of assemblies
๐Ÿ“Œ Replace components
ย
Practice CATIA Generative Shape Design
In this module, you will learn how to use the Generative Shape Design app to create curves and surfaces. You will also learn how to analyze the wireframe and the surface quality and rectify the detected defects and connect the geometries smoothly. Further, you will learn how to apply resilient modeling techniques to facilitate easy updation of part during design change.
๐Ÿ“Œ Create curves and improve the quality of the imported wireframes
๐Ÿ“Œ Create surfaces based on the wireframe geometries
๐Ÿ“Œ Assemble, re-limit and connect the surfaces smoothly to achieve the topology
๐Ÿ“Œ Analyze the surface quality and heal the defects
๐Ÿ“Œ Apply resilient modeling techniques
Practice CATIA Mechanical Systems Designโ€‹โ€‹โ€‹โ€‹โ€‹โ€‹โ€‹
This module will teach you how to create the architecture of a mechanism using simple wireframe elements and then complete the mechanism by adding 3D representations. You will also learn how to create a more complex mechanism using existing mechanisms, and finally how to animate the result.
๐Ÿ“Œ Create a new mechanism
๐Ÿ“Œ Manage the mechanism behavior
๐Ÿ“Œ Include alternative representations to complete the mechanism
๐Ÿ“Œ Create a new macro mechanism from existing sub-mechanisms
๐Ÿ“Œ Animate the mechanism
Practice CATIA Sheet Metal Design
In this module, you learn about the importance of sheet metal design. You will learn how to design a sheet metal part and make it ready for manufacturing. You will learn to define the sheet metal parameters and create a part using basic features.
๐Ÿ“Œ Explore different apps used for the sheet metal design and explain their advantages
๐Ÿ“Œ Define sheet metal parameters
๐Ÿ“Œ Create sheet metal parts using walls, bends and cutouts
๐Ÿ“Œ Manage folded and unfolded views
๐Ÿ“Œ Create stamped features and flanges
๐Ÿ“Œ Prepare part for manufacturing with sheet metal order process, DXF file and drawings
๐Ÿ“Œ Manage the design change
Practice SIMULIA Static Study
This course is an introduction to performing linear static simulations in the 3DEXPERIENCE Platform. The Static Study app enables designers to perform strength and deflection calculations under static conditions to validate product performance to guide design modifications. Designers can experience product performance virtually so that they can make better-informed design decisions early in the design cycle, when the cost of design change is low and opportunity is high.
๐Ÿ“Œ Search for simulation data in the database
๐Ÿ“Œ Open the simulation for modification
๐Ÿ“Œ Perform a simulation using the Static Study app
๐Ÿ“Œ Review simulations stored in a database and generate reports
Practice CATIA Generative Wireframe and Surface
This module will teach you how to use the Generative Wireframe and Surface app to create curves and surfaces. You will learn to efficiently assemble, re-limit and connect geometries. You will also learn to analyze the wireframe and the surface quality and rectify the detected defects.
๐Ÿ“Œ Create curves and improve the quality of imported wireframes
๐Ÿ“Œ Create surfaces using wireframe geometries
๐Ÿ“Œ Assemble, re-limit and connect the surfaces to achieve topology
๐Ÿ“Œ Analyze surface quality and heal defects
Practice CATIA 3D Tolerancing and Annotationโ€‹โ€‹โ€‹โ€‹โ€‹โ€‹โ€‹
In this module, you will learn how to annotate a 3D part. You will learn how to create annotation planes and how to add and manage 3D annotations on these planes. You will also learn how to create 3D views and use them to create 2D drawing views. You will also be able to create annotations on assemblies.
๐Ÿ“Œ Add 3D annotations to a part
๐Ÿ“Œ Manage and position the annotations
๐Ÿ“Œ Manage the 3D geometry associated to the annotations
Practice CATIA Quality Rules Reuse
In this module, you will learn how to share corporate knowledge stored in the rule bases and leverage it across the company to ensure design compliance with the established standards. You will also learn to create reports and manage their template.
๐Ÿ“Œ Automate the design modifications
๐Ÿ“Œ Analyze and create reports
ย
ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย EXPAND your capabilities with advanced apps of your role
Practice CATIA Smart Mechanical Components
In this module, you will learn how to define and reuse smart mechanical components. You will also learn how to define component specifications and place the component on the component specifications. Additionally, you will learn to define adaptive components.
๐Ÿ“Œ Define smart mechanical components
๐Ÿ“Œ Specify the various types of smart mechanical components type
๐Ÿ“Œ Define component specifications (anchors)
๐Ÿ“Œ Instantiate, reuse, place, move or delete smart mechanical components
๐Ÿ“Œ Create adaptive components
Practice CATIA 3D Annotation Insight
In this module, you will learn how to use the 3D Annotation Insight app to review and
filter 3D annotations information contained within part and assembly documents. You will
also learn how to hide / show annotations and captures, use the dimensioning and
tolerancing annotations to enhance understanding and improve the decision making.
๐Ÿ“Œ Access and visualize the view, capture and annotation review features
๐Ÿ“Œ Query and filter 3D annotations
๐Ÿ“Œ Show/Hide individual as well as all annotations of a given type
๐Ÿ“Œ Display FTA captures
๐Ÿ“Œ Remove the FTA clipping plane of a capture
๐Ÿ“Œ Filter 3D annotations
Practice CATIA Bent Part Design
This module will teach you how to use the Bent Part Design app to create and modify a sheetmetal part. You will learn how to define the sheetmetal parameters and create features such as walls, bends, cutouts and corners. You will also learn different techniques for multi-selecting the objects and constraining the parts.
๐Ÿ“Œ Define and modify the sheetmetal parameters
๐Ÿ“Œ Create a sheetmetal part using the wall and bend features
๐Ÿ“Œ Manage the folded and unfolded views of parts
๐Ÿ“Œ Create cutouts, chamfers and corners
๐Ÿ“Œ Constrain the parts
Practice CATIA FreeStyle Shape Design
In this module, you will learn how to create flawless, styled shapes from scratch using 3D free-form curves and surfaces or using digitized data. You will also learn how to analyze and enhance the quality of existing curves and surfaces.
๐Ÿ“Œ Create styled shapes using digitized data
๐Ÿ“Œ Create surfaces using the curve-based and the surface-based approaches
๐Ÿ“Œ Analyze and enhance the quality of curves and surfaces
Practice CATIA Mechanical Surface Refinement
In this module, you will learn how to use the CATIA Mechanical Surface Refinement app to modify and refine a mechanical surface in order to improve the surface quality.
๐Ÿ“Œ Create a preliminary surface design
๐Ÿ“Œ Analyze the result and identify problem areas
๐Ÿ“Œ Modify the design using styling surfaces
๐Ÿ“Œ Refine the design
๐Ÿ“Œ Complete a high quality surface design
Practice CATIA Digitized Shape Preparation
In this module, you will learn how to create a cloud of points and then process those points. You will also learn how to mesh the clouds, improve the mesh characteristics, align the cloud of points and perform deviation analysis.
๐Ÿ“Œ Create a cloud of points
๐Ÿ“Œ Process the points of a cloud
๐Ÿ“Œ Mesh the clouds
๐Ÿ“Œ Improve the mesh characteristics
๐Ÿ“Œ Align the cloud of points
๐Ÿ“Œ Perform deviation analysis
Practice CATIA Mechanical Systems Experienceโ€‹โ€‹โ€‹โ€‹โ€‹โ€‹โ€‹
In this module, you will learn how to define behaviors by manually recording an animation and by using laws. You will also learn how to include the analysis of measurements and accelerations. Furthermore, you will learn how to generate traces, swept volumes and snapshots which can be used while reviewing the simulation results.
๐Ÿ“Œ Create a scenario manually or by using laws
๐Ÿ“Œ Include measurement and interference analyses
๐Ÿ“Œ Generate results
๐Ÿ“Œ Create snapshots for a review
๐Ÿ“Œ Export the final simulation
ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย  ย EXPAND your capabilities with specialized roles
ย
Strengthen your skills & network with peers!
ย
๐Ÿ‘‰ Joinย CATIA USER COMMUNITYย to learn more about CATIA and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask questions, like and help in our online community!
ย
๐Ÿ‘‰ Join theย CATIA Creative Design & Styling - User COMMUNITY:ย
Our global community for designers, creatives & users of our creative design, surfacing & VR solutions to network and share their knowledge. Here, you can learn about design trends, processes and roles in 3DEXPERIENCE CATIA design and styling, as well as our VR and surface refinement solutions. Plus, you can interact directly with our champions and experts, view tutorials, webinars and event information, and ask questions. Help make this community yours by joining and contributing today.
ย
ย
๐Ÿ‘‰ Join theย 3DEXPERIENCE platform user's communityย to learn more about the 3DEXPERIENCE platform and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask a question, like, and help in our online community!
ย
๐Ÿ‘‰ Join theย ENOVIA User Communityย to learn more about the ENOVIA brand and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask a question, like, and helpย in our online community!
ย
โ€‹โ€‹โ€‹โ€‹โ€‹โ€‹โ€‹โ€‹โ€‹โ€‹โ€‹โ€‹โ€‹โ€‹โ€‹Content type :ย User Success Pathย
Brand :ย CATIAย ย
Role :ย
CSV-OC
M3S-OCย โ€‹โ€‹โ€‹โ€‹โ€‹โ€‹โ€‹
