🎓 Success Path: Mechanical and Shape Designer
Mechanical & Shape Designer
The CATIA Mechanical & Shape Designer role allows the users to create and complete highly complex mechanical products and parts, from conceptual to detailed phases.
🧑‍🤝‍🧑 Your profile
You want to create sheet metal parts and assemblies.
You want to create Parts and assemblies.
You want to create complex shapes and surfaces.
You want to use CATIA.
⌚ Estimated time
Onboarding: 6h 40m
🧑‍🏫 Your learning path starts here
Learn about a powerful set of applications built to allow the creation and management of sophisticated mechanical projects, including advanced & complex surface design.
Discover the value and usage of your roles and learn about their main apps articulation
Explore the Mechanical and Shape Designer Role
In this module, you will discover and practice the key capabilities of the Mechanical & Shape Designer role. You will also learn how to create and manage a complete mechanical project.
<i><strong>Key concepts covered:</strong></i>
📌 Leverage the 3DEXPERIENCE platform collaboration capabilities
📌 Create parts using various methods
📌 Design surface geometries
📌 Build sheet metal parts
📌 Import and modify external CAD models
📌 Construct and modify assemblies
📌 Animate and validate kinematic simulations
📌 Validate the manufacturability of parts
📌 Generate part and assembly drawings
3DEXPERIENCE Mechanical & Shape Designer [hands-on] - Associate
This certification validates knowledge and skills on the Mechanical & Shape Designer role within the 3DEXPERIENCE platform. This exam proposes hands-on challenges that will require you to design and modify parts and assemblies. You will also be asked multiple-choice questions (MCQ) on how to create 3D parts, create and modify assemblies, analyze parts and drafting. This exam includes exercises that require a 3DEXPERIENCE platform access including the apps related to the Mechanical & Shape Designer role. Prepare this exam by watching our video
Deep dive into the most important features of the key Apps and their practical usage in projects.
Start with technical videos 👉
Discover powerful features of Assembly Design
Discover advanced features of Assembly Design
Discover Life Cycle Management, Data Exchange with OEMs, Project Planning, Issue and Change Management, Using Dashboards
Practice CATIA Part Design
In this learning module, you will learn how to create 3D models using the CATIA Part Design app. You will also learn how to use different feature-based tools to build a 3D model. Further, you will also learn how to add parameters, reuse data, create models using tables, and modify a model.
📌 Create and constrain 2D sketches
📌 Design fully associative models in 3D
📌 Design reusable features
📌 Parameterize a model
📌 Use Multibody Boolean operations
Practice CATIA Drafting
This module will teach you how to create drawings using the Drafting app. You will learn how to create projection views and section views of a 3D model or an assembly and add the required dimensions.
📌 Create simple projection views and section views of 3D parts and assemblies
📌 Position the views on a drawing sheet
📌 Add dimensions and annotations to the views
Practice CATIA Assembly Design
In this learning module, you will learn how to create and manage assemblies and sub-assemblies in the design context. You will manage the positioning of parts and analyze assemblies. You will also learn how to modify the design in the assembly context.
📌 Create and manage assemblies
📌 Manage the positioning of parts
📌 Create engineering connections to specify the degrees of freedom of components
📌 Modify design in the assembly context
📌 Create flexible assemblies
📌 Calculate, declare, and examine the weight distribution of assemblies
📌 Replace components
Practice CATIA Generative Shape Design
In this module, you will learn how to use the Generative Shape Design app to create curves and surfaces. You will also learn how to analyze the wireframe and the surface quality and rectify the detected defects and connect the geometries smoothly. Further, you will learn how to apply resilient modeling techniques to facilitate easy updation of part during design change.
📌 Create curves and improve the quality of the imported wireframes
📌 Create surfaces based on the wireframe geometries
📌 Assemble, re-limit and connect the surfaces smoothly to achieve the topology
📌 Analyze the surface quality and heal the defects
📌 Apply resilient modeling techniques
Practice CATIA Sheet Metal Design
In this module, you learn about the importance of sheet metal design. You will learn how to design a sheet metal part and make it ready for manufacturing. You will learn to define the sheet metal parameters and create a part using basic features.
📌 Explore different apps used for the sheet metal design and explain their advantages
📌 Define sheet metal parameters
📌 Create sheet metal parts using walls, bends and cutouts
📌 Manage folded and unfolded views
📌 Create stamped features and flanges
📌 Prepare part for manufacturing with sheet metal order process, DXF file and drawings
📌 Manage the design change
Enrich your usage through advanced apps or additional roles
                                                 EXPAND your capabilities with additional roles
Mechanical & Shape Engineer
Specialized Roles
Strengthen your skills & network with peers!
👉 Join CATIA USER COMMUNITY to learn more about CATIA and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask questions, like and help in our online community!
👉 Join the CATIA Creative Design & Styling - User COMMUNITY
Our global community for designers, creatives & users of our creative design, surfacing & VR solutions to network and share their knowledge. Here, you can learn about design trends, processes and roles in 3DEXPERIENCE CATIA design and styling, as well as our VR and surface refinement solutions. Plus, you can interact directly with our champions and experts, view tutorials, webinars and event information, and ask questions. Help make this community yours by joining and contributing today.
👉 Join the 3DEXPERIENCE Platform User Community to learn more about the 3DEXPERIENCE platform and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask a question, like, and help in our online community!
👉 Join the ENOVIA User Community to learn more about the ENOVIA brand and to connect with your peers.
Content type : User Success Path
Brand : CATIA
Role :
CSV-OC
MES-OC
