fe-safe information and how to find it
Our fe-safe team is working to give you the insights you want whether you are just starting to use fe-safe or if you've used it for years. This includes several dozen questions and answers on our Knowledge Base, as well as links to frequently requested information on simulia.com. Find a curated list of fe-safe answers below.
Source Types
WebWeb page
KBQ&A article in the 3DS Knowledge Base
FilesMaterial shipped with the installation media [only available for customers]
General Information
Web: Online Documentation
Web: fe-safe product page on simulia.com
Web: fe-safe eSeminars
KB: Technical references on the theory of fatigue
KB: Understanding fe-safe terminology
Search for classroom or live online training courses on our Training Schedule & Registration page. On-site courses are also offered and can be customized to focus on topics of particular interest -- find out more, using our Request a Training course page.
Web: Support Contact in Your Region
Get fe-safe support from your regional SIMULIA office (Center of Excellence) or Authorized Support Center by finding your country at our Location Directory page.
Installation and Licensing
Web: Supported Platforms and Release Compatibility for fe-safe 6.5 and earlier
KB: fe-safe 6.5 release notes
KB: Abaqus FLEXnet license server daemons / utilities not available for stand alone fe-safe customers renewing lic
BR: Using an environment variable to direct fe-safe clients to an Abaqus Flexnet License Server
KB: DSLS Support for fe-safe and other established products
FEA Models
KB: Position naming in fe-safe v Abaqus
KB: What to know about plasticity for FEA Fatigue in fe-safe
Materials
Web: fe-safe plug-in for Nitinol fatigue​​​​​​​
KB: Creating new materials in fe-safe 6.4-02
KB: Estimating S-N curves from strain-life parameters in fe-safe
KB: Material properties for fe-safe/Rubber
KB: Searching for materials data in the fe-safe Materials Database
KB: Finding fatigue properties for fe-safe
KB: Using cyclic stress-strain curves with kinematic hardening plasticity in Abaqus (one backstress)
KB: Multilinear kinematic hardening model for cyclic plasticity (in Abaqus)
Loading
KB: Loading for a real-life oil-and-gas application
KB: Creating transient dynamic loading in fe-safe
KB: Creating a modal transient analysis in fe-safe from ANSYS
KB: Creating harmonic loading in fe-safe from ANSYS results
KB: Loading limitations with the uniaxial strain-life algorithm
KB: Setting repeats on a load block in fe-safe to zero
KB: Tutorial for fe-safe/Rotate using Abaqus
Webinar: PSD Fatigue in fe-safe
Automating Analysis
KB: Configuration of settings to automate fe-safe analyses in a macro file
KB: Automating the use of fe-safe/Rotate with Abaqus output database files
KB: How do I read the Logarithmic Strain (LE) variable from an Abaqus ODB while using automation in fe-safe?
Advanced Considerations
KB: Accounting for residual stresses in fe-safe
KB: Choosing between FOS and FRF in fe-safe fatigue factor calculations
KB: Do I need to run a plasticity correction outside fe-safe
KB: Frequency dependence in fe-safe calculations
KB: Gating stress tensors in fe-safe
KB: Using the Theory of Critical Distances to estimate the fatigue life of notched specimens
Add-on modules
Web: fe-safe/Rubber 30-min webinar
Web: Fatigue of Elastomers and fe-safe/Rubber 2-hour eSeminar​​​​​​​
Bug: Structural Stress is wrong on second order model in automatic weld finder for shells
KB: How to define spot welds by group
KB: Editing materials in the Verity database
KB: Will fe-safe/Rubber work for my material
KB: Using Verity to analyze welds per ASME Section VIII, Division 2 Weld Fatigue
Standards and specifications
KB: Does fe-safe support British Standard 7910?
KB: Does fe-safe conform to the DNV-RP-C203 standard?
Post-Processing and Viewing
KB: Automatically setting fe-safe post-processing options in Abaqus/Viewer or Abaqus/CAE
KB: How to determine damage per loading event or block in fe-safe
KB: Post-processing fe-safe output using Abaqus/Viewer
KB: Hex-nugget spot welds in Abaqus
KB: Post-processing Critical plane vectors from fe-safe 6.5-01 in Abaqus/CAE
KB: Using vector exports from fe-safe in Ansys Mechanical APDL
BR: Trouble post-processing Verity results on second order solids in Abaqus/CAE
Process Integration & Optimization
KB: Integrating Abaqus, Tosca, and fe-safe
KB: Integration of fe-safe 6.4-03 in Tosca Structure 8.1.0
KB: Error Using User Defined Load History in fe-safe Loading Definition File (LDF) with Tosca Structure 8.1
fe-safe Training Courses
Web: Introduction to fe-safe software training
Web: Automating Analysis in fe-safe
Web: Fatigue of welds in fe-safe
Web: Introduction to fe-safe/Rubber (Abaqus+fe-safe software class)​​​​​​​
Web: Tosca Structure.durability course (Abaqus+ fe-safe +Tosca software class)
Web: Request a Training course from DS SIMULIA
Web: Find an Education Partner in your area
Get fe-safe support from your regional SIMULIA Center of Simulation Excellence or Authorized Support Center by finding your city and zip code at our Locations page.
Further Simulia learning resources here on SLC
