SolidPractice Information
Domain and Role/Product
#SOLIDWORKS with Cloud Services
- Uninstalling the SOLIDWORKS software
- Deleting Specific Folders
- Deleting Registry Keys
- Deactivate the .NET Framework Software
- Uninstall the Bonjour Software
- Reactivate the .NET Framework Software
Revision History
Rev # | Date | Description |
1.0 | July 2020 | Document created. |
1.1 | Sept 2022 | Document validated for 2022 SP3 with minor updates. |
Note All SolidPractices are written as guidelines. It is a strong recommendation to use these documents only after properly evaluating your requirements. Distribution of this document is limited to Dassault Systèmes SolidWorks employees, VARs, and customers that are on active subscription. You may not post this document on blogs or any internal or external forums without prior written authorization from Dassault Systèmes SolidWorks Corporation. This document was updated using version SOLIDWORKS 2022 SP03. If you have questions or need assistance in understanding the content, please get in touch with your designated reseller.
Your Feedback Requested We would like to hear your feedback and also suggestions for new topics. After reviewing this document, please take a few minutes to fill out a brief survey. Your feedback will help us create content that directly addresses your challenges.
1) Preface
This SolidPractice presents a direct workflow that you can follow to remove existing installations of the SOLIDWORKS software, and replace the removed versions with clean installations.
The SOLIDWORKS software has close integration with the Windows operating system (OS). At times, dynamic-link library (DLL) files, which are responsible for Windows/SOLIDWORKS data exchange, break the link and cause odd behaviors in SOLIDWORKS. Often, a simple repair of the SOLIDWORKS installation cannot address this issue. In this case, it might become necessary to perform a clean installation of the software. A clean installation deletes all of the files and registry keys that link SOLIDWORKS and the OS. This process can help you save time when troubleshooting high-level issues. It can take several days to determine the source of a problem by using tools such as the Wireshark® network protocol analyzer and the Microsoft® Process Monitor tool. Common sources of such behaviors include Windows upgrades, SOLIDWORKS upgrades, corrupted registries (Windows and SOLIDWORKS), and interaction with third-party software.
To perform a clean reinstallation of the SOLIDWORKS software, follow the instructions in this document.
2) Return the SOLIDWORKS License to the Server
To return the SOLIDWORKS license to the server, follow these steps to deactivate the license:
- Go to Help > Licensing > Deactivate.
- In the SOLIDWORKS Product Activation dialog box, select the method of deactivation, and then click Next to complete the action.
3) Turn Off User Account Control (UAC)
- Press the Windows key, type User Account Control settings, and then click the item when it appears in the results list.
- In the User Account Control Settings dialog box, move the slider control to the Never notify level > click OK.
4) Uninstall the SOLIDWORKS Software
Before proceeding, if the system from which you are uninstalling the SOLIDWORKS software also has an installation of SOLIDWORKS PDM, see Appendix A.
Go to Control Panel > Programs > Programs and Features.
In the list of programs, right-click the SOLIDWORKS installation > click Uninstall.
On the Summary page of the SOLIDWORKS Installation Manager, ensure the selection of all components as shown in the next image.
Under Advanced Options, click Change.
On the Advanced Options page, select all of the options, and then click Back to Summary.
Right-click the SOLIDWORKS Installation Manager title bar, click Installation Logging Levels, and then click Create Windows Installer Logs (Slow). When active, this option creates installer logs that capture any issue during the installation.
Click Remove Items.
5) Delete Specific Folders
After uninstalling the SOLIDWORKS software, delete the following folders:
Note: It is always a best practice to back up program data before deletion.
C:\ProgramData\Solidworks
6) Delete Specific Registry Keys
CAUTION: Incorrectly editing the registry can severely damage your operating system. The SOLIDWORKS Technical Support team strongly suggests that you back up the registry data before making any changes to the registry.
- Open the Windows Registry Editor.
- Either rename or delete the following registry keys:
- HKEY_CURRENT_USER\SOFTWARE\SolidWorks
- HKEY_LOCAL_MACHINE\SOFTWARE\SolidWorks
- HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\VSTAHOST
- HKEY_LOCAL_MACHINE \SOFTWARE\Microsoft\VSTAHostConfig
For x64 installations, also delete the following keys if present:
- HKEY_LOCAL_MACHINE \SOFTWARE\Wow6432Node\Microsoft\VSTAHost
- HKEY_LOCAL_MACHINE \SOFTWARE\Wow6432Node\Microsoft\VSTAHostConfig
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\SolidWorks
7) Uninstall Other Software Programs and Components
a) Uninstall the C++ Redistributable Components
In the list of programs, uninstall all of the C++ Redistributable components.
b) Uninstall Specific Microsoft Visual Studio Components
Uninstall the Microsoft Visual Studio Remote Debugger and Microsoft Visual Studio Tools for Applications programs indicated by the red arrows.
To uninstall the Microsoft Visual Basic 7.1 software, open a Windows command prompt, and then enter the following command:
MsiExec.exe /X{90120064-0070-0000-0000-4000000FF1CE}
The Visual Basic application does not appear in Programs and Features.
8) Deactivate the .NET Framework Software
- Go to Control Panel > Programs > Programs and Features.
- In the left pane, click Turn Windows features on or off.
- In the Windows Features dialog box, deactivate the .NET Framework items by clearing the check box for .NET Framework item, and then click OK.
For example, in the following image, you would deactivate both .NET Framework items.
9) Uninstall the Bonjour Software
- Right-click the Bonjour program item > click Uninstall.
- After uninstalling this item, restart the computer.
10) Reactivate the .NET Framework Software
- After restarting the computer, return to Control Panel > Programs > Programs and Features.
- In the Windows Features dialog box, activate the .NET Framework items by selecting the check box for each .NET Framework item that you previously deactivated.
- Click OK to save your changes.
11) Install the Latest Version of the SOLIDWORKS Software
Before performing the new installation, it is important that you restart the computer once again. After restarting the computer, follow these steps:
Open Windows File Explorer, browse to the Download folder, and then open the PreReqs folder.
Sort the list of folders from A – Z.
Starting from the top of the list, install the following prerequisites (shown in the next image):
- Bonjour.msi (for 32-bit systems) or Bonjour64.msi (for 64-bit systems)
- All prerequisites that begin with VCRedist
- VSTA
After installing all of the prerequisites, browse to the sldim folder and run the sldIM.exe program as administrator.
IMPORTANT! When the SOLIDWORKS Installation Manager appears, make sure that the Create Windows Installer Logs (Slow) option is active. To confirm this, right-click the SOLIDWORKS Installation Manager title bar, click Installation Logging Levels, and then verify that a check mark appears next to the Create Windows Installer Logs (Slow) option.
Follow the instructions in the SOLIDWORKS Installation Manager to complete the installation.
For more information about upgrades and installation, read the “SOLIDWORKS Upgrades” SolidPractice document. This document is available from the Knowledge Base solution S-076254.
Appendix A: Considerations for SOLIDWORKS PDM
The SOLIDWORKS PDM software stores information in the SOLIDWORKS registry. If you use the instructions in this document to perform a clean uninstall of the SOLIDWORKS software, the SOLIDWORKS PDM installation will not function.
If the system from which you are uninstalling SOLIDWORKS also has an installation of SOLIDWORKS PDM, perform these additional configuration steps.
Before section 4 - “Uninstall the SOLIDWORKS Software”
- Export the following registry keys to .REG format files:
- HKEY_LOCAL_MACHINE\SOFTWARE\SolidWorks\Applications\PDMWorks Enterprise
- HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\SolidWorks\Applications\PDMWorks Enterprise
Before section 11 – “Install the Latest Version of the SOLIDWORKS Software”
- Import the previously exported .REG format files.
- Install SOLIDWORKS and then optionally install SOLIDWORKS PDM.
