About the role
The Structural Performance Engineer role allows you to:
- Provide product engineers powerful and intuitive tools needed to perform sophisticated structural simulations during the design process
- Experience efficient "what if" scenarios through seamless associativity/integration with geometry
- Use a unique engineering workflow with an access to robust simulation technology within an intuitive interface
- Work with multistep structural scenarios for product performance and quality testing during the product design process
- Accelerate structural performance simulation with unique automated model creation for large assemblies
- Enable high-performance results visualization, particularly for very large models
- Include local compute up to 8 cores
Note: you can use the anchor symbol in the top right of the post to jump to the section you're interested in. R2026x FD02
Performant and streamlined definition of a large number of loading features and pertinent load cases to represent aircraft operating conditions for internal loads analysis
Easily create high fidelity mesh of solid rods from 3D Part with automatic procedure of extracting the neutral fiber, meshing and defining its section properties
Optimize mesh orientation around holes by aligning patterns through constrained node movement along the circular boundary
User Experience Value
Rapidly select all faces of partitioned geometry as geometrical supports for quick definition of operating conditions
Easily create high end visualizations of orphan results with new part based rendering settings in Physics Results Explorer
Easy redefinition of mechanical contact numerical parameters enabling more accurate modeling of product physical behavior
R2026x FD01
Compare design alternatives leveraging SOLIDWORKS configurations for efficient what-if scenarios driving improved designs
Create high quality mesh with improved mesh flow algorithm addressing small geometric features such as holes, fillets and flanges
Easily amend intersecting model sections with enhanced automatic and manual tools to fix intersections and penetrations
Accelerate selection of specifications definitions with selection by propagation for topology edges and domains
Validate submodel accuracy by overlaying outputs with the global model
Easily review simulation results with results plot legend enhancements
Efficiently detect and create point fasteners based on placement lines
Simplify import of Abaqus input files by bringing in both the model and the materials in one step
Accelerate definition of supports with the ability to create mesh groups directly in the support manager while defining scenario features
R2026x GA
Simplify KPI-focused results exploration with a pass/fail view using new simulation goals in Physics Results Explorer
Accelerate mesh editing process with an easy method to quickly adjust edge seeding density
Simplified re-use of mesh subregions for defining simulation features by identifying groups of nodes/elements within a user selected geometric volume
Enhance accuracy of durability simulations with ability to define solid nugget spot weld construct in a Body-In-White model
Efficiently define and edit the operating loads of virtual products for a more streamlined model definition
Easily manage multi selection editing in the support manager with simplified access to common tasks
Easily interpret element quality information with the ability to display different colors for different quality failure types
Improved usability of the interference checker by displaying the penetration vectors at nodes
R2025x FD04
Reliably investigate and review material behavior with new material properties plotting capabilities
Easily asses the resulting forces on the Product with new display controls for Resultant Forces arrow representation
R2025x FD03
Enhance vehicle safety workflows with the availability of integrated section output definition and results visualization
Improve line fastener robustness involving multi-part overlapping scenarios with the availability of enhanced proximity detection techniques
Enhance modeling of heat transfer effects in thermal engineering applications with the addition of cavity radiation definition
Improve modeling efficiency and re-use with support for defining appropriate element types as part of the model definition
Expedient model diagnostic information loading and display for efficient results analysis and model troubleshooting
Easily review the mesh quality matrix of selective meshes with the enhanced Quality Report
Efficiently assess the load carrying capacity of idealized bolted joints featuring multi-layer definitions
R2025x FD02
Experience improved usability and efficiency for managing existing mesh with support for persistency of mesh editing operations when model changes are made
Easily generate high quality mesh with the ability to enable elements optimization from within the Mesh Part Manager
Flexibly and effectively use native applications and monitor simulations during execution with the new local interactive solve mode
Increase confidence in the produced mesh quality with quality plot display showing the criterion selected by the user with the relevant range of legend values
R2025x FD01
Efficiently create models of formed components using CATIA quick formability feature to initialize shell section thickness
Create high fidelity FE models including triangle/tet meshes with improved meshing capabilities by adding the mesh type as a user parameter
Easily produce high quality surface and volume mesh connections with the new functionality to merge nodes between a 2D and 3D mesh and to make the condensation persistent
Extend the applicability of line fastener constructs by adding new wedge element options
Build large assemblies of symmetric components efficiently with the ability to mirror a half symmetry FEM including connections
Efficiently create simulation models using new geometric defeaturing and idealization commands with the addition of the new Geometry Idealization Essentials application
Perform cloud-computed simulations during the design process with a new dedicated Computer center in Asia
R2025x GA
Easily produce high-quality surface and volume mesh connections with the new functionality to merge nodes between a 2D and 3D mesh and to make the condensation persistent
R2024x FD04
Easily and efficiently create Virtual Strain Gauges using CATIA model definition such as imposed points and model axis systems
Flexibly define Virtual Strain Gauges by specifying each length, width and tolerance at individual sensor position
Easily review simulation data size and delete them efficiently to optimize data storage in 3DEXPERIENCE
R2024x FD03
Accelerate and simplify access to the relevant output information with the new option to define unique default output requests
Easily access all relevant Role information through a dedicated dashboard with convenient and intuitive access to content and apps relevant to the role
R2024x FD02
- Increase efficiency of modeling assemblies and identifying intersecting entities with the new visibility and filtering options of interference checker results
- Improve usability and efficiency of scenario definition by cutting, copying and pasting scenario features of the model tree
- Experience improved usability and efficiency for managing complex assemblies with an improved way to create and edit Display groups with a refreshed dialog.
- Easily and reliably identify and correct disconnected mesh parts in an assembly based on the realized connections in the model definition to simulate complex assemblies more efficiently
R2024x FD01
- Build large assemblies that involve symmetric components with the new planar-symmetric FEM generation functionality
- Extend applicability of axisymmetric simulations with thermal simulations and physical pre-tension bolt loading
- Streamline simulation workflows based on Assembly of Meshes with automated Abstraction Shape creation
R2024x GA
- Manage multi-step scenario simulations quicker and easier with improved flexibility and efficiency
- Experience game-changing performance improvements of cloud results visualization for large models
- Diagnose and fix modeling issues quickly and efficiently with automatic detection of unconstrained motion
Experience game changing performance improvements of cloud results visualization for large models
R2023x FD04
- Reduce modeling time and enhance simulation quality with improvements to the mesh interference checker
R2023x FD03
- Maximize mesh data reuse and automate connection realization aided by the connection rules in Assembly of Mesh simulation models
- Improve mesh quality in surface meshes and partition hex mesh regions with enhanced manual mesh editing tools
R2023x FD02
- Diagnose and fix modeling issues quickly and efficiently with the new simulation job diagnostics
R2023x FD01
- Predict behavior and failure of adhesives with inclusion of cohesive element modelling
- Modify simulation settings quickly and efficiently by editing scenario features directly through the improved assistant panel
R2022x FD04
- Enhanced coupling connection capturing specified number of node rings around holes
- New factor of safety output for virtual bolts allowing a quick check if the bolt has failed or not
- Stress Linearization capability to extract membrane and bending stresses as requested by various industrial standards
New Stress Linearization capability in Physics Results Explorer to extract membrane and bending stresses as requested by various industrial standards
R2022x FD03
- New app introduction with Parametric Design Study Essentials- Single objective study identifying the best design in an intuitive experience
- New option for selective flipping of face normals when defining a cyclic symmetry or a fluid cavity on a shell-like model, avoiding any specific geometry modification requirement
- Visibility improvement by adding legends to colored mesh visualization (mesh quality, interference, etc) to better identify the elements associated with the visualization criteria
- Virtual Pin can now be defined on surface geometry removing an existing limitation
- User Experience improvements in the Property & Abstraction manager by allowing multiple properties selections in order to change the material behaviors or the thicknesses, reducing dramatically the number of clicks in such cases
- Structural simulations performed using this role (on cloud) can now be monitored from the Simulation Manager app, a web-based app available from any device
Meshing - Visibility improvement by adding legends to colored mesh visualization (mesh quality, orientation, etc.)
New app introduction with Parametric Design Study Essentials - SIMULIA Design Exploration with xDesign users
R2022x FD02
- Post-processing - New dedicated dialog box for virtual bolts results accelerating access to relevant outputs (force, moment)
- Integration of Physics Simulation objects to the 3DMarkup app to create persistent annotations and slides based on such data, useful for collaboration and design change process
- Support of SOLIDWORKS custom materials with simulation domain improving efficiency and re-use
- Meshing - Upgrade of the tet filler mesher algorithm leading to improvements in the mesh quality and robustness
Post-processing - New dedicated dialog box for virtual bolts results accelerating access to relevant outputs (force, moment, factor of safety, etc.)
R2022x FD01
- New Visualization Management tool for Simulation, merging Visualization & Visibility Control and improving usability
- Dedicated Property & abstraction Manager with advanced filtering functionalities to review and edit Properties and Abstractions, especially in large models
- Provide User experience enhancements for the meshing step allowing users to modify Quality parameters, check to smooth elements with good or poor quality, to Isolate and Fix Bad and Surrounding Elements (rectangular trap, ....)
- Enhance Mesh navigation and usability with management of the link from FEM to criteria file and management of the criteria threshold from the main quality analysis table
- Post-Processing - New camera setup feature allowing users to track any particular target and to follow the movement of a component during animations
- Offer Virtual Bolt Enhancements for virtual bolts creation and detection
Dedicated Property & abstraction Manager with advanced filtering functionalities to review and edit Properties et Abstractions, especially in large models
R2022x GA
- FEM integration in standard mass & inertia measurement tool, leveraging information available in Model Queries
- Meshing - New persistent locking options for elements and domains facilitating any remeshing action
- Modeling & Meshing -Support lap joint for the Support boundary method of line fastener reducing dramatically the time effort and effort to create the mesh in such case
- Post Processing - Ability to export sensor outputs to CSV file or document
- Improved model-build user experience with a unified app for meshing and structural model creation, improving efficiency
Modeling and Meshing -Support lap joint for the Support boundary method of line fastener reducing dramatically the time effort and effort to create the mesh in such case
Modeling and Meshing - New persistent locking options for elements and domains facilitating any remeshing action
R2021x FD07
- The Automated FEM command has been enhanced to support multibody for tria & quad surface procedure so users can easily select which body to be meshed with 2D elements
- New check and fix tools for compatible line fasteners connections are improving dramatically the meshing success rate
- New Connector behaviors to reach completeness in Virtual Bolt and Point Fastener
- Revamped Simulation Initialization for intuitive first steps enabling users to select up at a glance the simulation name, the analysis type, the analysis case name as well as an existing FEM
- New scroll bars and User Interface modification improve the user experience when defining material simulation model
- On-The-Fly axis system creation is now possible when dealing with scenario related features, improving dramatically the user experience
- Ability to create a new template from a plot definition and sensors has been added to the Post Processing phase for a straightforward subsequent reuse
The Simulation Initialization has been revamped for efficient and intuitive first steps
To improve the User experience when defining Material with Simulation Domain, the Simulation Domain editor has been enhanced with independent scroll bars and more spaces
The Automated FEM command has been enhanced to support multibody for tria & quad surface procedure so users can easily select which body (the main body, all geometries or visible geometries ) to be meshed with 2D elements
R2021x FD06
- Small sliding in General Contact for faster contact set up in linear cases
- Scenario – Support of hydrostatic pressure, regular load condition for pressure vessel simulations
- Modeling - New connection options (e.g. rigid elastic in connector behavior, distributing vs. kinematic couplings in connector and virtual bolt) to improve the connection modeling flexibility
- Post-Processing - Virtual Strain Gauge creation tool to define and output simulation results consistent with standard physical test measurement methods, and help determine best strain gauge locations for test
- Modeling - More options (e.g. search domain) provided for the fastener creation automation using data coming from the CATIA Fastening app
- Post-Processing - New variable contour transparency for contour rendering enhancing rendering settings for results data review or communication
- Deliver an example that uses the 3DEXPERIENCE Connector for SOLIDWORKS in the 3DEXPERIENCE Simulation Examples user guide
Ability to provide semi contour rendering capability in Post Processing phase
Deliver an example that uses the 3DEXPERIENCE Connector for SOLIDWORKS in the 3DEXPERIENCE Simulation Examples user guide.
Modeling - More options provided for the fastener creation automation using data coming from the CATIA Fastening app
R2021x FD05
- New Unified licensing model available for consistent licensing offer for compute. The SimUnit licensing (credits and tokens) will offer flexibility, scalability and Power to our user community
- Modeling - Support of new connection common behaviors (i.e. plasticity, damage, lock, stop) to increase the simulation fidelity
- Modeling - New feedback in the Visualization Management dialog box for the user to make sure what he is currently viewing
- Modeling and Meshing - Automated FEM enhancements (e.g. Support of multibody and visible body in midsurface and tetrahedron procedures) to improve the meshing automated processes
- Post-Processing - Allow results visualization during local simulation execution to ensure the model is behaving as expected and get intermediate results before the end of the simulation
Results visualization during simulation execution
R2021x FD04
- Complete support for multi-bodies in modeling (contacts, connections, abstractions...) auth
- Use "Hide/Show" in Scenario containers and "Show Only Hidden Features" in Feature Manager to improve efficiency of working with large assemblies
- Modeling – Display of the parameters of all connections in the Connection Manager for efficiently reviewing and comparing them, especially in case of large assemblies
- Modeling - Generative model build capabilities (ex. axisymmetric) to fully automate the simulation model creation following best practices to drastically reduce the time to go from design data to simulation ready model
- Post-Processing – Enhancement of the results comparison tool with new synchronization options (on legends, deformation) as well as easier simulation comparison from the search.
- Pre-Processing - Model Plots Enhancement to allow layout of plots with dedicated display options, name based filtering mechanism for queries (e.g. mass and volume)
New modeling capabilities for axisymmetric structures, drastically reducing turnaround times for simulations
Enable sequential thermal stress analysis to be performed using any increment of the upstream thermal analysis.
