IP Protection & Export Control
R2027x GA | Legacy to Strategic Apps Transition Overview
From R2027x GA onward, only Strategic (Next Gen) apps will be available, replacing all legacy apps.
The transition is as follows:
Legacy Apps (Cloud/Prem)Replacement Apps (Cloud/Prem)
ENOVIA IP Export Control Management
IP Security Manager (IPS) | GA
ENOVIA IP Protection and Export Control Classification
IP Controlled Access (IPA)
ENOVIA IP Protection Management
ENOVIA IP Controlled Access
IP Controlled Access (IPA) | GA
Demo
The following video illustrates the apps available in "ENOVIA IP Protection and Export Control Classification":
(note: the video contains a voice-over)
Features
Some features that were available in legacy applications are now offered differently in the replacement Next Gen apps.
These improvements reflect the new design and approach of Next-Gen apps, providing a more intuitive and streamlined experience while covering the same use cases.
FeatureComment
Discontinued
Export Record-
Question Tree -
Supported differently
Classification Summary (libraries and classes)
  • Legacy single-screen KPI view is replaced by distributed info.
  • Users can view libraries, classes, exceptions, drill down into sub-classes, and navigate classified items. Filtering by time range is available via the History tab.
Archive Expired Exceptions & Country Registrations
  • Exceptions can be archived using filters in the Exceptions tab.
  • Country registrations are managed in ENOVIA Collaboration & Approvals app, expired entries are archived from the Registrations tab.
Working with Routes & Issues
  • Use dedicated Routes & Issues widgets for managing routes and issues efficiently.
Manage Attribute Groups
  • Attribute groups are no longer needed. Attributes are fewer (limited to 20) and shown as standalone, which can be viewed or added directly.
Create Exceptions from Object Context
  • Exceptions per object are no longer recommended.
  • Exceptions should be created first, then relevant objects can be referenced.
Reclassify
  • Remove an object from one class and add it to another using “Add Existing Content”.
  • Use Classifications facet available in all apps (Information panel).
If you have any questions or comments on these topics, please share them with us below. 👇
Thanks!
