Please note: This page is for sharing information only; it is not a Q&A space or discussion forum. Any comments, questions, or support requests posted here will not be answered and will be deleted. If you have a question, please post it in the community so your peers and our team can respond.
Questions & Answers |
1. Does New Revision automatically replace the previous revision in structures?
When you create a revision of an object, the new revision does not automatically replace the previous revision in the structures in which it is used. You can manually replace this revision with the new one, for example with the Replace by Latest Revision command if the object type supports it.
2. How can I prevent users to use obsolete revisions in new structures?
No option in Collaborative Spaces Control Center allows you to prevent users from using revisions with the Obsolete maturity state.
However, you can use the "Connect" opening ID to implement a business rule script with your business logic.
3. What happens to attachments or related objects during Revision, Branch, or Duplicate?
It depends on the object type that you are revising, branching or duplicating, and the type of related object. For more information about whether a related object is added to the new revision, branch, or duplicate, see User Assistance of the related object, or the modeler node corresponding to the object type that you are revising, branching or duplicating in the PLM Components guide of the User Assistance.
Documents added as attachments or specification documents to objects are added to the new revision, branch or duplicate. They also remain attached to the revision that you selected to create the new revision, branch, or duplicate.
