Conversion Data Integrator for x (FOx) - R2024x FD01
(Tip: You can use the Table of Content  , on the right side, to view the list of all enhancements)
Support for New CAD Releases (FOA - Conversion Data Integrator for ACIS)
Why
Expanded support for a broader range of software releases
How
You can now deploy these converters with the following CAD format releases for ACIS
  • ACIS 2024
Support for New CAD Releases (FOC - Conversion Data Integrator for AutoCAD)
Why
How
You can now deploy these converters with the following CAD format releases for AutoCAD
  • AutoCAD 2024
Support for New CAD Releases (FOP - Conversion Data Integrator for Creo Parametric)
Why
How
You can now deploy these converters with the following CAD format releases for Creo Parametric
  • Creo 10
Support for New CAD Releases (FOI - Conversion Data Integrator for Inventor)
Why
How
You can now deploy these converters with the following CAD format releases for Inventor
  • Inventor 2024
Support for New CAD Releases (FON - Conversion Data Integrator for NX)
Why
How
You can now deploy these converters with the following CAD format releases for NX
  • NX 2306
Support for New CAD Releases (FOR - Conversion Data Integrator for Parasolids)
Why
How
You can now deploy these converters with the following CAD format releases for Parasolids
  • Parasolid 36
Import MultiCAD Data as a Shareable 3DShape (FOJ - Conversion Data Integrator for JT)
Why
Expand the options for importation of CAD shapes to support richer downstream use of the data in CATIA design structures
How
During the import, you can now decide whether to allow a 3D import of JT data as Physical Product or Shareable 3DShape
Shareable 3DShapes can be used in multiple types of product structures reducing the limitations on how imported data can be used
Support for New CAD Releases (FOV - Conversion Data Integrator for Revit)
Why
Expanded support tor a broader range of software releases
How
You can now deploy these converters with the following CAD format releases for Revit
  • Revit 2023
If you have any question or comments on these highlights, please share them with us below. 👇
Thanks!
