General hotfix for DraftSight 2026 error: "Failed to load modules" during startup. (Regression from 2025SP4)
An issue was identified in DraftSight 2026 that causes "Failed to load module" during DraftSight startup. This is an environment specific error and observed on computers with non English characters/Symbols in the Windows user name. This is regression from DraftSight 2025SP4 hence possible workaround for this error was to downgrade DraftSight installation to 2025.
It was reported in BR10000427478 / BR10000438273 and has been fixed in DraftSight 2027SP1 which is will be released in Feb 2027 (pending successful QA and testing)
The DraftSight development team have provided a hotfix that once applied, will resolve the issue in DraftSight 2026SP4.
In order to install the hotfix, please follow these steps:
  • Make sure DraftSight 2026SP4 is installed on the computer.
  • Download the HotFix_HF-1584996_2026SP04.exe shared below to a local folder on your PC (*this HF is applicable only for DraftSight 2026SP4)
  • Unzip the file.
  • Make sure DraftSight application is closed. Double click to run the installation executable.
  • Follow the instructions to install the hotfix in your pc.
  • After successful installation, verify that the hotfix appears in Programs and Features with the correct HF number.
  • Proceed to launch DraftSight and test the issue.
    HF for 2026SP4:
    Removal:
    Before applying any future service packs of DraftSight, please be sure to remove this Hotfix.
    This can be done by following these steps:
  • Open the Windows > Control Panel  (Type "Control Panel" into Windows Search tool on the Task Bar)
  • Select Programs and Features
  • From the list of Programs, right click on DraftSight HotFix_HF-1584996
  • Select "Uninstall/Change" and follow the steps to remove the Hotfix: DraftSight HotFix_HF-1584996
