UX Openings
UX Openings
Introduction:
UX openings help control how users interact with the system, especially in:
  • New (creation) screens
  • Properties / Information panels
They guide users while entering or updating data by controlling what they can see, edit, and select.
With UX openings, the system can:
  • Prevent incorrect or unwanted entries
  • Show only relevant fields
  • Lock fields when changes are not allowed
  • Provide instant messages or warnings before saving
These capabilities work in the background to keep information accurate and aligned with business requirements.
In simple terms: users are guided step-by-step, mistakes are reduced, and data stays clean and reliable.
The screenshots below demonstrate how the system guides users by:
  • Displaying warning messages for invalid inputs (without blocking the save action)
  • Restricting editing through read-only fields
Scenarios Covered:
This framework is organized into four core scenarios.
Each has its own detailed documentation page with EKL scripts, examples, explanations, screenshots, and demo videos.
ScenarioWhat It EnsuresExplore Details
1. Read‑Only Enforcement
Locks attributes once populated; attribute conditionally locked.
Read-Only Enforcement
2. Authorized Values Restricts inputs to predefined lists.Authorized Values
3. Input Validation & Feedback Blocks empty/invalid entries; warns on non‑blocking issues.Input Validation & Feedback
4. Conditional Visibility Dynamically shows/hides attributesConditional Visibility
Technical Context:
  • Version: 2026x GA (On‑Premise) / HotFix 1.32 (Cloud)
  • Execution Context: Server
  • Trigger Points: Save in dialogs, Information tab, Instance tab, and property value changes in the Properties page
  • Licenses Required: TXO, MFN / MGA / RME
Disclaimer:
Licenses mentioned above are as per 2026x documentation.
How the System Works
To make this easier to understand, let’s look at what happens from a user’s perspective:
1. During Creation
  • User clicks New / Insert New
  • The system prepares the screen (default values, visibility rules)
  • As the user enters data:
    • Inputs are validated
    • Allowed values are enforced
    • Messages guide the user
2. During Modification
  • User opens the Properties / Information panel
  • The system adjusts what can be seen or edited
  • When values are changed:
    • Validation runs instantly
    • Fields may become read-only
    • Errors or warnings are displayed
How this openings Trigger:
Process Flow
This diagram shows how user actions automatically trigger system logic to apply validation, control visibility, and enforce rules during creation and modification.
Opening IDs and Their Trigger Conditions:
Opening ID
Description
For more Information, see...
compute_new_init
Fired when New panel is build
New Initialization
ux_init_new_modify
Fired when the user modifies an attribute in New
New Modify
compute_edit_properties_init
Fired when Properties experience is built
Properties Initialization
ux_init_edit_properties_modify
Fired when the user modifies an attribute in Properties
Properties Modify
Limitations:
  • Direct table edits in UI → BLs are not triggered when values are changed directly in spreadsheet view.
  • Multiple row selection → BLs do not apply when modifying several rows at once.
  • Native client → BLs have no effect; changes are not visible in the native client.
