How to deploy (On-premises, Cloud)
Overview
This document provides a clear, step-by-step guide for deploying a ER Generic Server Openings using the Data Setup application.
It covers the following key steps:
  • Creating a Business Rule
  • Deploying the Business Rule
  • Exporting the Business Rule
  • Importing the Business Rule into another environment
Prerequisites
Version – 2026x GA (On-Premise), 2026x FD01 (On-Cloud)
Pre-requisites – User must be assigned with Owner Role or  Administrator role
Licenses – Customization and Specialization Administrator (TXO)
On the <strong>3DEXPERIENCE Platform</strong>, only users with <strong>Owner</strong> or <strong>Administrator</strong> roles can access and use the Data Setup application.
Before we begin:
In your Development or Sandbox Environment, you will:
  • Create the business rule
  • Deploy the business rule
  • Export the business rule
After exporting, import the business rule into production:
  • In Private or Dedicated Cloud, use Enterprise IP Schema Specialization
  • In Public Cloud or On-Premises, use Data Setup
    <strong>Recommendation:</strong> Always create and test rules in Dev/Sandbox before moving to Production
Following steps can be followed to deploy the Precommit trigger (ER Generic Server Openings) Business Rules in Data Setup App:
  1. Login to 3DExperience as Admin or other user with Owner role.
  2. Click on compass and open the Data Setup app
1. Create a Business rule
Step 1: Open Resource Tables
  • Go to Resource Tables
  • Right-click and select Create a New Resource Table
Step 2: Create Resource Set
  • Enter a name for the resource set
  • Click OK
Step 3: Assign Business Rule
  • Find the Opening row
  • In the Resource column, double-click Unset
Step 4: Create New Rule
  • Click “Create a new business rule”
Step 5: Enter Details
  • Enter the rule name
  • (Optional) Select scope
  • Click OK
Step 6: Configure Rule
  • Select the ThisObject type
  • Enter your business rule logic
  • Click OK
Step 7: Save
  • Click OK to save
Your Business Rule is now created and ready for deployment.
2. Deploying a Business Rule
Steps to Deploy
  • Find your Resource Set
  • Right-click and select Deploy Server Business Rules
Note:Precommit business rules do not need to be bound to a collaborative space in Data Setup before deployment.
Deployment is allowed only in:
Development environment (Private/Dedicated Cloud)
Sandbox (Public Cloud)
4. Undeploying a Business Rule (If Needed)
Steps
  • Locate the runtime view
  • Right-click and select Undeploy Server Business Rules
5. Exporting Business Rules
Steps to Export
  • Find the runtime view
  • Right-click and select Export Server Business Rules
  • Save the .zip file to your computer
6. Importing Business Rules
For a cloud, you can export from development environment(refer step 5) and import on cloud
Steps
  • Go to Data Setup → Resource Tables
  • Right-click the Resource Table
  • Select Deploy from External ZIP File
  • Upload the .zip file
Other References
Server Business Logic Rules on the Public Cloud - "How to"
