Me Preferences - Common settings
Purpose
Common setting recommendation in contect of Fluid systems Design
🛈 Only the parameters that have changed from the standard are listed. If they are not mentioned, keep the original settings.
2D 3D View Display
Performance
Value to be adjusted according 3D model size. For mere details about Setting for Large assembly performance , see dedicated wiki page
Change setting to avoid visualizing 3D thin objects in wireframe dash line --> reduce value in Level of Details setting
Parameters, Measures and Units / Parameters
Parameters & Relations
Save in Knowledge.xml
<CATSettingRepository Name="Knowledge">
    <Attribute Name="ParametersViewWithFormula" Type="int" Size="1">
        <Value>1</Value>
    </Attribute>
    <Attribute Name="ParametersViewWithValue" Type="int" Size="1">
        <Value>1</Value>
    </Attribute>
</CATSettingRepository>
Object Properties / 3D Shape
Display
Save in part.xml
<CATSettingRepository Name="part">
    <Attribute Name="UpdateExternalReferences" Type="int" Size="1">
        <Value>1</Value>
    </Attribute>
    <Attribute Name="VisuRelation" Type="int" Size="1">
        <Value>1</Value>
    </Attribute>
    <Attribute Name="VisuParameter" Type="int" Size="1">
        <Value>1</Value>
    </Attribute>
    <Attribute Name="VisuConstraint" Type="int" Size="1">
        <Value>1</Value>
    </Attribute>
Infrastructure
Save in PartDocument.xml
<CATSettingRepository Name="PartDocument">
    <Attribute Name="WireframeComponentCreationMode" Type="short" Size="1">
        <Value>1</Value>
    </Attribute>
Object Properties / 3D Shape / Infrastructure
3D Shape Infrastructure
Save in SelectSettings.xml
<CATSettingRepository Name="SelectSettings">
    <Attribute Name="SelectLink" Type="int" Size="1">
        <Value>1</Value>
    </Attribute>
Multi Discipline Automated Engineering / Basics
Engineering Knowledge Language
Save in knowledge.xml
    <Attribute Name="ExtendedLanguage" Type="int" Size="1">
        <Value>1</Value>
    </Attribute>
Global Design Management / Product Finder Classic
Visualization
save in VPMNavigator.xml
<CATSettingRepository Name="VPMNavigator">
    <Attribute Name="TurntableAnimation" Type="int" Size="1">
        <Value>0</Value>
    </Attribute>
    <Attribute Name="TurntableReframe" Type="int" Size="1">
        <Value>0</Value>
    </Attribute>
Global Design Management / System Finder
Explore
Save in RFLPNavigator.xml
<CATSettingRepository Name="RFLPNavigator">
    <Attribute Name="SmartOpen" Type="unsigned int" Size="1">
        <Value>3</Value>
    </Attribute>
