Why does the meshing sometimes fail?
Hey guys,
I have a problem regarding the reliability of my meshing procedure for the following simulation scenario:
The simulation is a 2-degree rotationally symmetric problem. It includes a vertically moving coil along an rotationally symmetric shaft. The rectangular box around the shaft and the coil is a refining feature for better seeding control.
It is a manually coupled model, which means: At every coil's position, there is an electromagnetic step (induction heating) first. Secondly, there is the respective thermomechanical step (for heat flux, phase transformations, and mechanical properties). I always need an identical shaft mesh in all steps to ensure that all nodes and elements (IDs) can communicate the stored and calculated information like temperature etc..
The whole shown model is designed as one part with different regions/sets like shaft, air, coil, and cooling water inside the coil. At every time step, the script creates a new CAE with the new coil's position.
I apply this sequence via scripting in the EM-CAE file:
1. Setting (global) element type and mesh controls
2. Setting global seeding size for the whole part
3. Creating the refining features (rectangular box), then seeding these new edges
4. Seeding the shaft region, then meshing the shaft region
5. Seeding the coil + water regions, then meshing the coil + water regions
6. Finally, meshing the air regions
The actual problem:
This way has been working for coarse meshes, but it seems to gradually fail with finer meshes. Trying to mesh the air region manually in the CAE-GUI leads sometimes to a perfect mesh without any issues and in other cases to the error "meshing failed due to poor element/mesh quality". However using "Mesh Part" instead always works perfectly, but this will reorder all nodes and element IDs in every step which does not work in my case.
How can this be?
Do you have any ideas on how to mesh this model in a better and especially a more reliable way?
Thanks a lot in advance!
Answers 0
