What to do with Abaqus error- system error code 1073741819?
I get the error like this:
Error in job top-center-cylinder-0-CP_100_100X50: The executable standard.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
Job top-center-cylinder-0-CP_100_100X50 aborted due to errors.
I have also tried to rename the mkl_avx2.dll in (C:\\SIMULIA\\Abaqus\\6.13-1\\code\\bin) to mkl_avx2.dll.11.0.0.1. and also to mkl_avx2.dll.13.0.0.1. But its not working.
the weird thing is that the code can run in other simulation.
Answers 0
