Substructures in heat transfer analysis?
I am trying to model the heat transfer in a bridge cable in Abaqus/CAE and I would therefore like to use substructures. I am using DCC2D4D elements. When I submit the job I get the following error message: "At least one of degrees of freedom 1 thru 6 or 8 must be active in the model for this procedure type. Check the procedure type and elements used in this model." I have retained some DOFs in my model and if I change the element type to CPE4R I can submit the job with no errors. I would therefore like to know if it is possible to use substructures in Abaqus/CAE with heat transfer elements.
Answers 0
