Socket error: [Errno -2] Name or service not known
Hallo,  i know openSuse leap is not supported by Abaqus, but i hope someone still can help me with my problem.
  After i Submit a Job i get the following error:
Analysis initiated from SIMULIA established products
Abaqus JOB Reflection_Heat
Abaqus 3DEXPERIENCE R2016x
Abaqus License Manager checked out the following licenses:
Abaqus/Standard checked out 8 tokens from Flexnet server license-win.zfn.uni-bremen.de.
<110 out of 200 licenses remain available>.
Begin Compiling Abaqus/Standard User Subroutines
Tue May 16 11:27:00 2017
End Compiling Abaqus/Standard User Subroutines
Begin Linking Abaqus/Standard User Subroutines
End Linking Abaqus/Standard User Subroutines
Tue May 16 11:27:01 2017
Begin Analysis Input File Processor
Run pre
terminate called after throwing an instance of 'nex_PrimException'
Tue May 16 11:27:05 2017
Abaqus Error: The executable pre
aborted with system error "Abnormal termination signal" (signal 6).Please check the .dat, .msg, and .sta files for error messages if the filesexist.  If there are no error messages and you cannot resolve the problem,please run the command "abaqus job=support information=support" to report andsave your system information.  Use the same command to run Abaqus that youused when the problem occurred.  Please contact your local Abaqus supportoffice and send them the input file, the file support.log which you justcreated, the executable name, and the error code.
Abaqus/Analysis exited with errors
Base System : openSUSE Leap 42.2 64-bit
Fortran compiler : gfortran
Abaqus 2016 Build ID:2015_09_24-22.31.09 126547
I found a similar Error in a Forum: http://www.eng-tips.com/viewthread.cfm?qid=240196 . The answer is the system is misconfigured but the Link is to a Abaqus answer ID 3858 who dont work anymore. Anyone have an idea?
Answers 0
