Hello everyone,
I would like to gather feedback from the community regarding the analysis of cable-net structures and the most suitable Dassault Systèmes solution for this type of problem.
I am currently investigating a structure consisting of an interconnected cable network, similar to those commonly used in children's playground climbing nets. The structure is anchored at several boundary points and subjected to vertical loads applied at nodes within the network.
My primary objective is not to calculate cable stresses or size the cables. Instead, I need to determine the reaction forces at the anchor points, particularly the horizontal reaction components, which will later be used for the design and verification of the supporting steel structure.
I initially attempted to solve the problem using SOLIDWORKS Simulation 2026 with a nonlinear static study. The cable network was represented using beam elements with hinged end releases in an attempt to approximate cable behavior.
During discussions with SOLIDWORKS Technical Support, several important observations were raised:
- Beam elements do not fully represent true cable behavior due to their bending stiffness.
- The structure is inherently unstable because of the nature of the cable network.
- Cable pretension effects are difficult to represent accurately in SOLIDWORKS Simulation.
- The new Cable Connectors available in SOLIDWORKS Simulation 2026 cannot currently be used to create a complete cable-net structure.
- Arc-Length Control was suggested as a possible approach to improve convergence.
I have also performed additional analyses using Arc-Length Control, but I continue to experience convergence difficulties.
This has led me to wonder whether I might be trying to solve a problem that is beyond the practical scope of SOLIDWORKS Simulation and would be better addressed using a SIMULIA-based workflow.
I would therefore be very interested in hearing from users who have experience with:
- Cable-net structures
- Tensile structures
- Pretensioned cable systems
- Membrane structures
- Form-finding analyses
- Abaqus and SIMULIA roles within 3DEXPERIENCE
In particular:
- Have you successfully analyzed cable-net structures within the Dassault Systèmes ecosystem?
- Which product or 3DEXPERIENCE role did you use?
- Did your workflow involve a form-finding stage before applying external loads?
- Were you able to obtain reliable reaction forces at the anchor points?
- Would you recommend Abaqus / SIMULIA for this type of analysis?
Any experience, recommendations, examples, or best practices would be greatly appreciated.
Thank you in advance for your insights and participation.
Best regards,
Alberto Quintela
EASYWORKS
SOLIDWORKS & Simulation Consultant
