Riks method
 I have two questions:
 First question:
 When I use Riks method for a structure that is subjected to a distributed pressure load, I get this warning:
 WARNING: The node/nset None assigned under *STATIC,RIKS to be monitored for exceeding a maximum displacement must be an assembly-level nset. The monitoring will be ignored.
I ran the following Example: 1.2.1 Snap-through buckling analysis of circular arches, model "snapbuckling_deep" in Abaqus 6.11 documentation.
 Second question:
For the following keywords: *ELPRINT
*NODEPRINT, *PREPRINT That are written in most input files examples provided in the documentations of Abqus 6.11.1 whenever I run the input file in Abaqus I receive this warning:
 WARNING: The following keywords/parameters are not yet supported by the input file reader:
*ELPRINT
*NODEPRINT
*PREPRINT
How can I fix this ?
Thank you,
Answers 0
