Micromechanics Plugin for Abaqus/CAE v1.15 Bug: Incorrect computation of specific heat
Hello!
I've discovered a bug in Micromechanics Plugin for Abaqus/CAE v1.15 (the plugin is distributed through the DS Knowledge Base as Q&A article QA00000046185). In heat-transfer scenario the plugin uses volume fractions of constituents to calculate specific heat, which is wrong. One must use mass fractions instead.
EXAMPLE
In the attachment you can find an input file of a model of honeycomb RVE (please rename file extension from *.txt to *.inp). Foil in honeycomb has aluminum properties, while filler corresponds to air.
Specific heat of constituents:
- aluminum: 900 J/(kg K)
- air: 1004.9 J/(kg K)
Mass fractions of constituents:
- aluminum: 0.9773
- air: 0.0227
Volume fractions of constituents:
- aluminum: 0.0184
- air: 0.9816
Hand calculation of RVE's effective specific heat:
Cp = 900 * 0.9773 + 1004.9 * 0.0227 = 902.38
Result of calculation using Micromechanics Plugin:
1002.92
Check if the plugin uses volume fractions instead of mass fractions:
900 * 0.0184 + 1004.9 * 0.9816 = 1002.97
Apparently, it does...
SYSTEM INFORMATION
The bug has been found in Micromechanics Plugin for Abaqus/CAE v1.15.
Abaqus version: 2019.HF6 (fix pack 1947).
OS version: Windows 10 Pro 1803, 64-bit.
Best regards,
Mikhail Kozlov
