How to extract clamping force after applying bolt pretension in Abaqus/Standard?
Hello everyone,
I am performing a bolt pretension analysis of a steering yoke and pinion assembly in Abaqus/Standard.
The bolt tightening is simulated using a bolt pretension section, and contact is defined between the yoke and pinion. After applying and locking the bolt pretension, I would like to determine the actual clamping force generated between the yoke and pinion/contacting surfaces.
My main questions are:
  1. What is the recommended method to calculate/extract the clamping force after bolt pretension?
  2. Which Abaqus output variables should be used for this purpose?
  3. Should the clamping force be obtained from:
    • contact normal force such as CNORMF/CFN or related contact outputs,
    • bolt pretension section force,
    • reaction force,
    • or by integrating contact pressure over the contact area?
  4. If contact pressure is used, what is the recommended method in Abaqus/CAE to obtain the total resultant normal force over the contact surface?
  5. Is there a direct history output or keyword available for extracting the resultant clamping force?
My objective is to evaluate the compressive force transferred from the yoke to the pinion after bolt tightening, rather than simply reporting the originally applied bolt pretension load.
I would appreciate any suggestions regarding the appropriate output request, keyword, or post-processing method.
Thank you.
Answers 1
JS
JS 2026-10-22
No idea what your model looks like, but I recommend searching the documentation for history output variable CICPS.
