How to ensure continuity between adjacent 1D Beam meshes in 3DEXPERIENCE?
Hi all,
I'm modeling a stepped 1D beam (fork leg with 3 different diameters) in 3DEXPERIENCE.
Currently, I have 3 separate collinear line segments with 3 Beam Mesh features, which leaves duplicate coincident nodes at the joints. Using kinematic couplings between them overconstrained the DOFs and broke the bending behavior (gives "No Value").
What is the cleanest, native workflow to ensure full 6-DOF continuity here?
  • Is there an easy way to merge coincident beam nodes across meshes?
  • Or should I create a single partitioned curve and assign local beam sections to it?
Answers 1
AB
AB 2026-10-27 Best Answer
yes you need to activate "Nodes and mesh edges on constraints" in the Capture sub section of the beam mesh
comment imagecomment image
