Hi!
As shown in the image, a cylindrical pin only partially enters a hole. In the CAD, the hole is a single continuous face.
When creating a Tie Connection, Abaqus naturally triggers WarnNodeMissMainIntersect for the nodes on the empty bottom portion of the hole.
Is there a quick way inside to restrict the Tie only to the contact region without having to manually split the face in Part Design?
Thanks for any tips!
No idea. Why don't you just ignore the warning message?
You could create a surface representing the area you want to tie, create a proximity group(s) using that surface as the support, and then add a the tie constraint using that (those) groups. Or you could partition the face so you can select just the overlapping region. All of these are extra work to end up with the same Tie constraint the solver will automatically produce.
The easiest option is just to check the diagnostic set due to this warning and ensure it contains only nodes you expect to be missing intersection. This warning message can otherwise safely be ignored.
