I am currently simulating a model in which, after several analysis steps, I have obtained a final stage configuration. I would now like to transfer the results from this final stage to a subsequent analysis.
The challenge is that the geometry at the final stage differs from the initial geometry. For example, in my model, I start with a horizontal rectangular plate, then remove certain portions to create the final stage. If I want to set up the next analysis, I would need to create a geometry corresponding to the final stage, but the mesh would inevitably differ from the original model.
Could you kindly advise on how to accurately map the results from the final stage to a new model with a different mesh? Any guidance or recommended workflow would be greatly appreciated.
Thank you very much for your time and consideration.
Best regards,
Shishir
