FEA of Single Indent in Shot Peening
Dear ,
I am very pleased to learn Abaqus contact mechanics from your channel.
I am performing a Contact mechanics problem.In which I am not able to simulate the problem.It would be kind of you if you could help me with this.
My Example problem : FEA of Single Indent in Shot Peening.
I want the Steel sperical ball(Dia=0.36mm) should strike Aluminium metal plate(3.6x3.6x1.3mm) from a distance of 6mm above the metal plate and at an angle of 60degrees and with a velocity of 30000mm/sec,and the after causing an single depth/dimple indent on the metal plate and then the ball bounces back.
I tried a lot of ways to perform but still I could not do it.
This is my email id : saptarshee1991@gmail.com.
It would be really really kind of you if you could help me with this.
Thanking You
MITRA Saptarshee
Answers 0
