I'm trying to simulate a large metasurface (MS) structure illuminated by a horn antenna using CST Studio Suite v2025. As the distance between the MS and the horn is quite large, I would like to setup a hybrid simulation to reduce the duration of the calculation. Is there a application note on how to setup this ? What solver should i use on the MS , i'm assuming that i should use the Integral solver on the feed.
Thank you in advance
0
