CST - HF Frequency Domain (hex) at 13.56 MHz with posed voxel human: "Solver setup" dominates and runs on ~1 core
Environment: CST Studio Suite 2026 (academic license), AMD Threadripper PRO 32 cores, 512 GB RAM, Windows 11.
Model: wearable copper-tape coil (6.6 m loop, 9 discrete ports = feed + 8 capacitor gaps) on the posed Gustav voxel model (scaled to 170 cm). HF Frequency Domain solver, hexahedral mesh, single frequency 13.56 MHz, port 1 excitation.
Benchmark with a 10 mm mesh (2.0 M cells, 6.1 M DOF):
(a) Default iterative solver: Solver setup 159 s, solver 20 s (5 iterations, accuracy 7e-7), total 182 s.
(b) UseHelmholtzEquation = True: setup 168 s, total 194 s (no improvement).
(c) Type = Direct: factorization 1148 s, total 1151 s.
With a 5 mm mesh (9.5 M cells) the run did not finish within 15 min, and CPU usage stayed at about one core during the setup stage.
Q1: Is the hex FD "Solver setup" stage (preconditioner construction?) single-threaded? Is there any setting to parallelize or shorten it?
Q2: For electrically small problems (wavelength 22 m) with voxel bodies and discrete ports / lumped capacitors, which solver is recommended: HF-FD hex, HF-FD tet (does it support voxel models?), or the LF frequency domain solver (full-wave / EQS)?
Q3: Any recommended mesh settings for voxel human models at low frequency to keep the cell count manageable?
Thanks in advance.
Answers 0
