Hi, I am trying to use the python API to control an existing model, however I am struggling to find a way to change the value of a parameter. For example, a microstrip line has a parameter, "line_length" that controls the length of the line. I would like to be able to change this parameter in an external python script. Implementation would be along the following lines:
cst_directory = rsys.path.append(cst_directory) import cst environment = cst.interface.DesignEnvironment.connect_to_any_or_new() cst_file_path = r project = environment.open_project(cst_file_path) # Code up to this point works fine I can inspect the project object and it's sub-classes.
I can confirm the existance of a parameter via the following line which outputs "True" if it exists:
project.model3d.DoesParameterExist()
However, looking through the variables of model3d, it doesn't look like there is any such function that would operate in the following way:
project.model3d.change_parameter_value(, )
Is there a way to achieve this?
Thanks in advance.
