CST - Error in CST Studio when importing secondary electron data
Hi.
On my university computer, I have access to CST Studio Suite versions 2022 and 2024. I am trying to do some particle simulations, involving secondary electrons. But this version has the limitation that I cannot utilize GPU acceleration unless I import the data manually. But when I try to import the file, CST gives an error and the file closes.  The SEY data file is a normal ASCII text file as recommended by CST for import purposes. The error log is as follows:
Output from stdout:
This is the modeler 2024.1 Release from 2023-10-16 (change 1181985)
Startup: 10.01.2024 15:39:40
Modeler affinity of main thread: 111111111111111111111111
thread setup step 1 (analyze system) : 12, 24
sockets : 1
cores per socket: 12
ht units : 2
acc. hw : 24
OSI log : CPUID: selected engine is 'Leaf 0xB detection'
apic ids : 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27
apic ids (fallback): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27
from cpu registers: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27
fallback: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27
combined: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27
max id per cpu: 32
SMT mask: 1
Core mask: 1e
Package mask: ffffffe0
set results:
- packages: 1
- cores: 12
- smts: 2
generate core map, new implementation
0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23
packages: 1
cores : 12
ht units: 2
thread setup step 2 (affinities) : 12
thread setup step 3 (openmp environment): 1024 --> 12
Modeler openmp threads: 12
Parallel ACIS is active. Starting 24 worker threads for ACIS.
4 blocks read in parallel from ACIS file. 4 top level entities in total.<br />
How can I circumvent this? I need this simulation performed ASAP.
