ASME design by analysis. Stress linearization.
Hello everyone!
I need a help from someone, who is advanced in ASME codes or others. The problem is pipeline system with internal pressure and temperature distribution (hot fluid inside the pipeline). I calculated temperature field and applied it in my finite-element structural model (3D solid elements, linear elastic material models). The model includes flange connections with applied bolt preloads. The analysis converged, so I got the resulting stress distributions. I am familiar with the aspects of stress linearization procedure and understand the operations with stress tensors. But I don't fully understand, what criteria to apply in this case when I have primary (pressure) and secondary (temperature) loads acting simultaneously. How to separate Pm, Pb and Q stresses from the resulting fields? How to assess the strength of bolts in this case? Uneven temperature distribution has a great influence on the bolts, because they remain cold while pipeline heats up and expands. I'm not sure that this stresses in bolts are secondary in this case.
Will it be correct to calculate Pm and Pb by additional FE analysis where all coefficients of thermal expansion are equal to zero?
Any ideas?
Abaqus ​​​​​​​
Answers 0
