While running the Abaqus job on the cluster, why always the Slurm_job manager writes in "slurm_jobID.out" the following line::
"/var/share/slurm/d/job1120523/slurm_script: line 29: import: command not found".<br />
Here is the full output of the "slurm_jobID.out" file::
========================================== SLURM_CLUSTER_NAME = my_cluster_name SLURM_JOB_ACCOUNT = user_account_name SLURM_JOB_ID = 1120523 SLURM_JOB_NAME = job_name SLURM_JOB_NODELIST = cn[010-012,118,168-169,173,207-208] SLURM_JOB_USER = user_name SLURM_JOB_UID = 6811 SLURM_JOB_PARTITION = standard-low SLURM_TASK_PID = 17451 SLURM_SUBMIT_DIR = work_dir_path SLURM_CPUS_ON_NODE = 1 SLURM_NTASKS = 40 SLURM_TASK_PID = 17451 ========================================== /var/share/slurm/d/job1120523/slurm_script: line 29: import: command not found Checkout succeeded: standard/EECAD700DBEA License file: ################ License Server: ################ Checkout succeeded: parallel/35495086D91A License file: ################ License Server: ################ Abaqus License Manager checked out the following licenses: Abaqus/Standard checked out 23 tokens from Flexnet server ################ <197 out of 250 licenses remain available>. Checkout succeeded: Comp-FL/83E337DA6EEC License file: ################ License Server: ################ Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.2.199 Build 20180210 Copyright (C) 1985-2018 Intel Corporation. All rights reserved. Checkout succeeded: Comp-FL/83E337DA6EEC License file:################ License Server: ################ Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.2.199 Build 20180210 Copyright (C) 1985-2018 Intel Corporation. All rights reserved. 0: Running on cn010 2: Running on cn012 6: Running on cn173 8: Running on cn208 1: Running on cn011 3: Running on cn118 7: Running on cn207 4: Running on cn168 5: Running on cn169 0: Exiting on cn010 2: Exiting on cn012 6: Exiting on cn173 8: Exiting on cn208 1: Exiting on cn011 3: Exiting on cn118 7: Exiting on cn207 4: Exiting on cn168 5: Exiting on cn169 0: Running on cn010 2: Running on cn012 6: Running on cn173 8: Running on cn208 1: Running on cn011 3: Running on cn118 7: Running on cn207 4: Running on cn168 5: Running on cn169 slurmstepd: error: *** JOB 1120523 ON cn010 CANCELLED AT 2023-03-24T11:12:13 DUE TO TIME LIMIT ***<br />
Here is the section of my script using the "import" command::
node_list=ABAQUS_NODES import os srun hostname | sort > \\\$node_list nodes="\\\$(cat ABAQUS_NODES)"<br />
Thank you for your answers
Abaqus
