We have implemented a route-based release process for part approvals, where drawings are attached as representations of the corresponding parts. Hence the release of a part promotes the represented drawing to 'Released' as well.
When a part is released through a route and the route is completed, we expect the approver information from the route to be captured and populated into the mapped fields of the drawing.
However, when a part is released via the route, the system only records "User Agent" for the first task instead of capturing the actual responsible users for all the tasks who approved the route.
Route details:
Route Base Purpose is 'Standard' and Route Completion Action is 'Promote Connected Object'
Attached part to the route:
Mapped properties on the SW drawing:
Final view on the drawing title block after completion of route
Could you help us understand what might be causing this specific issue?
Thank you!
I believe you are experiencing this BR: https://support.3ds.com/knowledge-base/?q=docid:BR10000434770
It seems to only happen where you have activated the option to couple the lifecycle of the drawing and part together. If you turn off that option, add the part and drawing to the route content, then test the results.
