I have downloaded a block that has a label, but the label is invisible. It only shows up above the block when i select it on its grip point, as if I wanted to drag it. I would like that label to show up constantly and be in the print out of the drawing. Is there a setting in the block that I can change so all labels for that block are visible always, every time I insert it in any file? I attached the block.
Thanks!
0
