Subject: DraftSight 2026 SP4 STEP export uses INCH instead of Millimeters
Hello DraftSight Support Team,
I would like to report a possible issue with STEP export in DraftSight Enterprise Plus 2026 SP4 x64.
My drawing and unit settings are configured in millimeters. However, when exporting the 3D model to STEP (*.stp), the generated STEP file defines the global length unit as INCH.
The generated STEP file contains:
Plain Text
1
#5=(LENGTH_UNIT(*NAMED_UNIT(\\\$)SI_UNIT(.MILLI.,.METR*.));
2
#6=LENGTH_MEASURE_WITH_UNIT*LENGTH_MEASURE(25.399999999999999)*#5);
3
#7=(CONVERSION_BASED_UNIT('*NCH',#6)LENGTH_UNIT()NAMED_UNIT(#8*);
Show more lines
and:
Plain Text
1
GL*BAL_UNIT_ASSIGNED_CONTEXT((#7,#11,*13))
2
Show more lines
Therefore, the STEP file uses
#7, which corresponds to INCH, as the global length unit.If I manually edit the STEP file in Notepad and change:
Plain Text
1
GLOBAL_UNIT_ASSIGNED_CONTEXT((#7,#11,#13))
Show more lines
to:
Plain Text
1
GLOBAL_UNIT_ASSIGNED_CONTEXT((#5,#11,#13))
Show more lines
the STEP file is imported with the correct dimensions.
I have verified the DraftSight drawing settings and the drawing is configured in millimeters.
Tests already performed:
- DraftSight Enterprise Plus 2026 SP0 x64 showed the same issue.
- DraftSight was upgraded to 2026 SP4 x64, but the issue remains.
- Drawing Unit System / Block units format was checked and set to Millimeters.
BIMUNITSLENGTH = 6(Millimeters).SETBLKINSUNITwas tested, but changing this setting did not correct the exported STEP file.Could you please confirm whether this is a known issue with the STEP exporter in DraftSight 2026?
Ideally, the STEP exporter should use the drawing's millimeter unit (
#5) inGLOBAL_UNIT_ASSIGNED_CONTEXT, without requiring manual modification of the STEP file.Please let me know if you need the original DWG file and the STEP file generated by DraftSight to reproduce the problem.
Thank you.
