I'm trying to make a titleblock block with different line weights using print styles associated with the lines, but when I make a block out of them, the print styles of the lines are ignored. When I explode the block, I see the print style of each line defaults to bylayer. When I used AutoCAD I used color dependent plot style tables, which worked great with blocks. Color dependent print syle tables don't work properly with Draftsight, so I'm trying print styles and getting frustrated. Print styles work fine when blocks aren't involved.
0
