Paper Size Bug?
Is this the correct place to submit bug reports?
I really like Draftsight, but I have one major problem. Maybe it’s me, but I think it’s a bug.
When I make a copy of the paper sheet, the white/gray area isn’t duplicated onto the new sheet. If I right-click on the original sheet’s tab and then Print Configuration Manager, it will say “Print Size/Orientation: 34 x 22 Inches (Landscape)”. But on the new (copied) sheet, Print Configuration Manager says “Print Size/Orientation: 9 x 11 Inches (Portrait)”.
This happens in the current V1R4 and the older versions too.
 For consistency we, always set out paper space to use D size paper (34 x 22) and then print on a large plotter, or 11 x 17 or 8.5 x 11 as needed.
It appears Draftsight is setting the new (copied) sheet’s paper definition from some default template instead of from the source of the copy. (Also, I can’t find where the default template is set. Why is it picking the new Print Size/Orientation to always be “9 x 11 (Portrait)”).
Thanks.
Answers 0
