How to control PDF options via API
I am writing an automation that opens an AutoCAD drawing in DraftSight, and saves as PDF.  The problem is, the page size, orientation, scaling, etc. are pre-selected, and the drawing goes off the edge of the page.  It is not obvious as to what properties to manipulate to change this, or how to manipulate them - many of them return the variant type Object instead of a class type, and I cannot find any examples of how to do this.
Here is what I have so far.  I thought maybe accessing the PrintManager.AvailablePaperSizes() might lead me there, but it is not clear what type of object that returns.
    Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
        Dim dsApp As New DraftSight.Interop.dsAutomation.Application
        If dsApp Is Nothing Then
            MsgBox("Error - Unable to launch DraftSight.")
        Else
            Debug.Print("Success.  Attempting to open drawing...")
            Dim file1 As String = "C:\\Users\\jimerman\\Desktop\\L51AR00200C00.dwg"
            Dim tmpfolder As String = Path.GetDirectoryName(file1)
            Dim dsDoc As DraftSight.Interop.dsAutomation.Document = dsApp.OpenDocument(file1, _        dsDocumentOpenOption_e.dsDocumentOpen_Default)
            If dsDoc Is Nothing Then
                MsgBox("Error - Unable to open document '" & file1)
           Else
                dsApp.Visible = False
                Debug.Print("Success.  Attempting to save PDF...")
                Dim baseName As String = Path.GetFileNameWithoutExtension(file1)
                Dim saveName As String = String.Format("{0}\\{1}.pdf", tmpfolder, baseName)
                Debug.Print("-- Output name: " & saveName)
                Dim prtMgr As DraftSight.Interop.dsAutomation.PrintManager = dsApp.GetPrintManager()
                prtMgr.Printer = "PDF"
               prtMgr.PrintOut(1, saveName)
                dsApp.CloseDocument(file1, False)
            End If
            Try
                dsApp.ExitApplication()
            Catch ex As Exception
            End Try
            MsgBox("Done")
        End If
    End Sub
Answers 0
