Fillet radius won't display or print
This just started happening to me about two weeks ago. I will use the filet radius command. I select the two lines and enter. It extends the lines to the point where they would intersect the tangent of the radius but the lines stop there and the radius will not display on screen or print. This also applies only to a radius on an outside corner. The radius fillet displays just fine on inside corners. Any help is really appreciated. Thank you.
UPDATE: After some tinkering today I discovered that this problem only happens with fillets smaller than 1.00 units whether it be English or metric. Once I increase the size to 1.00 or more the radius displays just fine. This only perplexes me more. Any ideas or suggestions would be great! Thanks.
Kyle
Answers 0
