When I edit block attribute values and I try to for example change first three letters, I click the value and set the cursor in front of the string, I start typing the first letter, and as soon as I do it - the cursor automatically jumps/skips to the end of the string so the second and third letter are being added at the end of the string. Is there anything I can do to fix it? It is extremely annoying when you have to click to set the cursor in right position for each letter in the string you want to replace. Alternatively I can write it at the end and copy paste which is also time consuming and annoying.
Regards,
Szymon
0
