Robot in Singularity
Hi all,
I created a Robot Surface Simulation task in 3DEXPERIENCE from a surface trajectory, which generated 220 tags along the geometry. After checking the Auxiliary Axes Programming and validating the task, all 220 points appear as solved and reachable.
However, when I run the simulation, it suddenly stops due to a Robot Singularity halfway while traveling (using linear/Cartesian interpolation) between two specific tags. Since the singularity does not occur at a specific tag where I could simply change the robot configuration, but rather during the continuous path between them, how can I avoid or smooth out this transition?
For instance, should I change the Robot Orientation mode from "2-Axis" to "Wrist"? My main concern with switching to "Wrist" is losing perpendicularity to the surface along the path, which is critical here since this is an ultrasonic inspection process. Is there a recommended way to prevent the singularity while strictly maintaining surface normality?
Thanks a lot in advance and kind regards,
Answers 1
LM
LM 2026-11-18 Best Answer
Hello, without seeing your path entirely, My first suggestion would be to start the robot further down the track so that Joint 5 will be bent.  An like wise when you get toward the end, limit the robot from going all the because the robot is directly in front of the path right now, the robot will pass through singularity, so you need to program the rail position in a way that can bend the wrist. If you can position the product higher / lower that could help as well. Or put the robot on a Riser on the Slide if the part position is fixed...
