Hello everyone,
How can I simulate the attached mechanism in 3DEXPERIENCE DELMIA Equipment Design using the ETR role?
A rotating slotted arm drives a follower constrained by a fixed cam groove, making the gripper beam rise, move horizontally, and lower.
I am considering one Revolute, two Prismatic, and two Point Curve connections, with the arm angle as the only input.
Is this approach correct? How should I configure the Point Curve connections and motion command? Any tutorial or example would be appreciated.
Attached: simplified STEP model and preview image. Thank you!
Hello @DB . Do you have an idea about this question ?
Hello @ZC you are on the correct path. Driving joint will be revolute, two non-command prismatic joints and two point curve engineering connections. The point will be on the transfer assembly at the pin location. Curves will be at the center of the groves. I have created a voice over video which will walk you through this exact example, I have also uploaded the device completed. I posted it to our wiki here:
