Hi everyone,
I'm having an issue with Dynamic Probe Simulation in DELMIA Equipment Simulation or Robot Simulation.
I've created a simple setup with one rotating plate and one box. With Dynamics probe enabled, the box falls onto the plate as expected. However, when the plate rotates, the box stays in its original position instead of moving with the plate.
Has anyone experienced something similar? Is there any specific setting or configuration I might be missing?
I've attached a short video and the 3DXML file in case anyone would like to take a look.
Any suggestions would be greatly appreciated. Thanks in advance!
This is the 3DXML File
@GA We can achieve this with Virtual Commissioning application and conveyor simulation to generate a constant part. If you do not have Virtual Commissioning then you can only do this with the parts that are in the cell, but the key is to put them under a Manufacturing Product. Please see videos and dataset:
@GA . your request is understood, I'm investigating and come back to you
@GA . I've just got the answer, we are not yet supporting this use case. Sorry for that.
