I’ve noticed some issues with the visibility of certain 3D models in Work Instructions native app.
Capable Resource
Is there a way to display a capable resource model? It does display in 3D buildup in 3DOperation Viewer web app.
I know, that there is a different way of assigning resources other than "Capable Resource". But I thought, that Capable Resource is the preffered way. What if I’m using web apps for process authoring and native app for Work Instructions?
Out-of scope Provided Part
This is simillar to the previous one. When a Provided Part that i scoped to a Physical Product is added to MBOM structure (by insert - without implement link). It is, again, visible in 3DOperations Viewer. But it doesn’t display in Work Instructions.
What is the way of displaying these additional models in Work Instructions app when the underlying process is created with web apps?
Hi @ŠP,
You can display also Capable Resources in Native Work Instructions. Please check if you have Area linked to workplan and Resource Usage line filled for assigned Resource - this is mandatory to have Resource 3D Model visible in the BuildUp.
Later, you have to have this Area with linked Resources opened in your authoring session and ensure that in Product BuildUp options panel you have selected "Show only selected Resources".
In case you still face issues after, ensuring above points, please let me know.
Actually...The second one I managed to resolve. Defining a "Use Case" as "Assembly" did the trick. The question about Capable Resource is still relevant though.
